Question about Lands Phones
I have a samsung dcs 4x8 phone system when i try to call an extension i get unavail cbt. i changed the ring type to ring but still grting the error
5 Suggested Answers
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
  • 108 Answers
SOURCE: Samsung DCS Compact: How to connect MOH
Hi Dave,
Sorry I've been out of town and I'm just catching up. I looked at the info I sent to you and eventhough it is under the heading of Compact I think it is for a Prostar. The info is under the DCS heading and is called " DCS Technical Manual August 1995" Pages 186, 187, 197 and 200. I have not given up and I'm looking through my other reference materials but you are right, there are a lot of user and programming guides but no installation guides. I'll keep trying, so do not give up. "Talk" to you soon ....Mitelmike
Posted on Nov 18, 2008
SOURCE: How do I change the name on my Samsung Prostar DCS 24B phone?
To Program an extension name:
1 Press the TRSF key and dial 104
2 Enter the name using the dial keypad like you are texting
When the next character you want appears on the same key press the volume UP key to move the cursor on space to the right.
To make any changes press the volume DOWN key to move the cursor to the left .
If you want lower case letters press the A key brfore entering letters.
3 Press the TRSF key to store the name
HTH
Jo
Posted on Dec 18, 2008
  • 19 Answers
SOURCE: extension does not ring goes to paging message
Sounds like the DND button is on. There should be a round button in the upper area above the keyboard that says FWD/DND push till it is off. Should not light up but that is more a installers preferance then anything.
Posted on Apr 14, 2009
  • 2976 Answers
SOURCE: How can I Change which phone # rings on my Samsung DCS-LCD-12 ?
That will have to be changed where the lines come into the office, in the router.
Posted on Aug 24, 2009
We are located @ burningtree countryclub in decatur alabama. we have a samsung dcs 24 phone system with three lines. two of the lines are for the majority of the club and one line is dedicated to the pro...
Hi, try checking that the pro shop number is set to ring at their extension and not a group. to do this;
press Transfer
1234
1 to enable
speaker (blue key)
then type 714. use the volume key to take you to the number of the pro shop, then use the 3rd softkey under the screen until you get to the destination required. I have posted a video off the http://www.abbeytelecom.com website explaing more about how to do this.more like these are on this site.
Sep 02, 2011 | Samsung Prostar DCS Phone
I have a problem with my Samsung iDCS 28D phone. All incoming calls used to be routed to me by default (unless caller specifically punched in a different extension). Calls are now being routed directly to...
try dialing 600 to clear call forwarding, then re-set your forwarding to busy/ no answer followed by the VM number.
I have uploaded a 'how to' video, more of these are at http://www.abbeytelecom.com
I hope this helps.
May 12, 2011 | Samsung DCS 12 Corded Phone
How to program a dss key on a samsung dcs 24B
The easiest way to show you how to program you dss key is to watch the video attached, you need to make this a DS key and then input the extension number or try the following
Transfer 200
1234
Speaker
MMC 722
Once in 722 type the extension number in the bracket at the top of the screen. The curser will then drop down to the button 1 key which will be call 1. Always keep the call 1/ 2 keys!!!
Press the button that you want to change and find the command on the relevant button.
Jan 18, 2011 | Samsung DCS 12 Corded Phone
I am trying to set up speed dials on a samsung dcs-12b but keep getting a message saying no speed block and can't get any further
To assign a speed dial block you have to be in customer programming and go to MMC 606, once in type in either system-wide or individual extension number, please be aware that extensions can only have 5 blocks of 10 (50) speed dials, whereas the system can have 200+ depending on the size of the phone system. just to confirm 1=10. I have posted you a video explaining how to program the speed dial which is available to view on YouTube along with many others relating to the Samsung phone system. Alternatively you could visit www.abbeytelecom.com.
Nov 12, 2010 | Samsung DCS 12 Corded Phone
How do I turn the ringer volume down on my Samsung DCS 24? I have tried hitting the volume down button while the phone is ringing but that didn't work.
Hi, to change the ringer volume on your Samsung DCS - with the handset down, press TRANSFER 114, then hit 1 to 8 on your keypad - (1 being the quietest setting) please look at the video I've posted for you, If you find this useful checkout YouTube search 'abbeytel' where you will find over 60 more 'how to videos' relating to the Samsung DCS
Apr 20, 2010 | Samsung DCS 12 Corded Phone
Our samsung system only rings on one telephone- how do I get it to ring on all phones and lines
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Mar 16, 2010 | Samsung 816 Keyset Display Telephone
Need to assign 5 extensions to a group and auto forward incoming calls to all of them
Which system? Ring groups are set up with 500-529 access codes, notably 529 is the one for voice mail. Look in your installers guide for MMC that deals with HUNT groups and assign the extension to a new group.
If you need a manual, post back with your system model.
Carl
Oct 28, 2009 | Samsung Prostar DCS Phone
Aug 24, 2009 | Samsung DCS 12 Corded Phone
HTH
Jo
Dec 02, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Night mode off
Does the Main Phone, usually the Receptionist have a button labeled RTO ( Ring Plan Overide ) ? If it does then this button can be used to change the ringing destination. If the button is on the Reception phone then press the RTO key, enter Password ( 0 0 0 0 ), 2 ( assuming ring plan 2 is Day mode ),then hang up. If this totally messes up your ringing then cancel the above by pressing the RTO again, enter password ( 0 0 0 0 ), 0. Let me know how it goes, the phone system type is what I was asking for and it should be marked back in the phone closet where all the phones are connected. Talk to you later
Jul 30, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Lands Phones Logo
107 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
