Question about Dell Axim X30 Pocket PC
Axim x30 connection
Got the usb cable axim 30 don't know where to start
Ok...first what you want to do is take the usb which is attached to the cradle and plug it into your computer. Then if your computer is old you might want to download active syn. From there you can synchronize your personal information
Posted on Apr 16, 2009
I have an Axim x30 and I am in the process of flashing the bios. Everything went well until it started to copy the new bios to the device. The message came up "lost usb data stream". Now there is no usb...
May i direct you to this site : http://www.pocketpccentral.net/help/dellx3reset.htm
It shows how to soft reset and hard reset your Axim. I believe that after a hard reset your axim shall sync and you should try updating the rom again.
I take it you were using a rom update from Dell?
Best Wishes
Karlos
Jun 28, 2009 | Dell Axim X30 Pocket PC
Backup battery
its in the back of device a slight curved flap is given just lift that flap and its there.
Sep 18, 2008 | Dell Axim X30 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Cant connect to internet using my dell axim x30 helppppppp
http://www.fixya.com/support/t1775615-connect_internet
just answered this for someone else, if you have any other problems get a hold of me on twitter @clarkb16
Feb 23, 2009 | Dell Axim X30 Pocket PC
OLD AXIM 30, NEW DESKTOP COMPUTER RUNNING VISTA
Everything you need should be in the Vista native Synch center
http://www.microsoft.com/windows/windows-vista/features/sync-center.aspx?tabid=1&catid=1
Jan 03, 2009 | Dell Axim X30 Pocket PC
NEW DESKTOP COMPUTER RUNNING WINDOWS VISTA
all you havce to do is hook up the cradle to the USB port, and you MIGHT have to and i stress this because it will usually open on its own, you may have to open windows mobile device center, its in your programs menu, activesync is no longer used in VISTA, so any attempt to put it on will probably be stopped , once oyu plug in th ePDA check for updates, this will ensure that you have all the drivers for the Dell X30 (i)
Just purchase the usb cable for dell axim x 30 don't know where to start
plugging it in is a start. after plugging it into your pc and the pocket pc you can start using it
Dec 02, 2008 | Dell Axim X30 Pocket PC
Screen frozen with vertical lines
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
Dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
Jun 14, 2007 | Dell Axim X30 Pocket PC
Dell Axim X30 Pocket PC Logo
136 people viewed this question
Alun Cox
