MSI Wind Netbook sd card reader failure
I have an MSI Wind Netbook laptop that has a 7 in 1 card reader.
I inserted a Kingston 2GB SD card, and it detected and launched it.
I filled this card with data, and used the safely remove hardware option to eject it.
But after that first use, card insertion no longer is detected, and cannot be browsed or accessed in any way, it is like the reader is no longer there.
I have taken the following steps to resolve the problem, with no results.
1. Reboot the system
2. Try a different SD card
3. Re-install the driver for the card reader
4. Close all other programs and detach all peripherals from the system
  • 5 more comments
  • nicholasbhow Dec 03, 2008
    love4ce,
    I took your advice and tested both sd cards in another pc, and they operate normally.
  • wtbglw Dec 11, 2008
    Exactly the same issue :(
  • Anonymous Feb 25, 2009
    I tried solution number one posted by Jrosen1 and it still doesn't work.
    Any better alternatives?
    I un-installed and then reinstalled the card reader drivers
    to no avail as well.
    Help.
    I've got the same problem as you and incidentally I am also using a 2GB Kingston. I've already tried numerous fixes and nothing is working.
  • Anonymous Feb 27, 2009
    I had the exact same problem. None of the SD Cards I used (SD, SDHC, MicroSD) would work. I tried Jrosen's solution and it works. I'd try it.
  • bpagac Apr 23, 2009
    Same problem.  Brand new Wind 120, dead SD card Reader.  BUT Jrosen1's fix worked.  Thanx!!!  Glad I didn't waste time downloading drivers, etc.  I love easy fixes.
  • Yasser Mahmood
    Yasser Mahmood May 11, 2010
    please first try the sd card in other device like phone or other pc.
For both an MSI Wind running Windows and Mac OSX 10.5.(4,5,6) do the following. Shut down the MSI Wind. Remove the power cord, any USB peripherals, and any SD cards in the slot. Remove the Battery Hold down the power key (with the battery removed for 2-5 seconds)  Release the Power Key Insert the Battery Insert the the Power Supply plug ((do not insert any USB or SD card yet)) Power on the Wind Now, insert the SD card-it should now show up on the desktop (in OSX). That should do it. Now insert any USB dongles/cables etc...
You have reset the PMU and bus start up. Any more Wind Questions?
Jay Rosen-WindManOSX
Posted on Jan 10, 2009
Thanks Jrosen1 .. that solved my issue too. I appreciate you took the time to document the fix! try{for(var lastpass_iter=0; lastpass_iter
Posted on Feb 14, 2010
Worked for me, thanks !
Posted on Jan 10, 2010
  • webvan Jan 10, 2010
    Sorry, just wanted to add a comment !
How to tranfer photos from laptop to sd card mmc reader
There should be a slot on the left side of laptop that says sd, just insert the sd card and it will download the pics straight away
Feb 25, 2012 | MSI Wind U100-030US Laptop
Tip
Long boot up time on MSI netbook when Kingston micro SD adapter installed
Found a strange symptom on a MSI netbook with Windows 7 Starter OS; it would take a long time to boot up. After the initial Windows splash display, the screen would go blank, and take several minutes to come back to the logon screen.
After many trials with reloading the whole drive, checking disks, finally isolated it to the presence of the Kingston micro SD adapter, but without a micro SD card in the adapter.
Without a flash card in the adapter, it apparently tries to access it regardless, and hangs things up for a long time. Removed the adapter, and it booted and shut down almost instantly in comparison.
The adapter is not a simple pass through of the micro SD card, so if there is no flash card installed, leave it unplugged, or it may slow things down considerably.
Didn't find anything on a search related to this symptom and problem, so I thought I'd note it just in case anyone else runs into this situation, maybe save them some time troubleshooting...
on Jul 13, 2010 | Computers & Internet
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
I have a sylvania notebook i want to change os how do i do that i have no cd rom do i use a usb flash windows ce is harable.
To the best of my knowledge, you cannot change the OS on that notebook as it is an embeded system. The Gsystem is burned into a chip on the mother board and the only way at present is to reprogram a like chip and solder it in place after de-soldering the old chip. Then you would have to buy another embeded system and learn to program an EEprom chip.
Sep 17, 2010 | Sylvania G-Netbook
Unable to access CD/2GB due to drivers how can i stall the driver
you do one thing to install dual o.s in your system and solve your problem
Apr 04, 2010 | Kingston 4GB Secure Digital High Capacity...
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Jan 04, 2010 | Kingston 2GB Secure Digital Memory Card
I just bought an epc 7'' mini laptop on ebay. It was brand new and sealed in the package when i got it. When I turn the unit on, the Smart Book logo comes on and across the bottom it says ''loading OS...
This is the update program link:
you will need to download the above
http://zeng.h1.28823.cn/VT8505Software.rar
After you get the software, you need to find a SD card which is more than 512M to copy the software to setup the software.
Please do as follows:
1. Please decompress the files , open the VT8505 folder. Then copy the file “script” to your SD card.
(Very important, you only need copy the script folder to your SD card. don't include the VT8500 or VT8505 folder.)
2. Turn off your netbook,
3. Insert the SD card to your netbook.
4. Turn on your netbook. Then the software will setup to your netbook Automatically. Usually it will take several minutes to complete setup.
5. After completed setup. It will show a windows screen calling for your to turn off the netbook.
6. Pull the SD card out off the netbook.
7. Then turn on the netbook and all shoudl work fine.
Dec 30, 2009 | MSI Wind U100-016US Laptop
Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Feb 23, 2009 | Dell Inspiron E1505 Notebook
KINGSTON 4GB MEMORY SD CARD
Check if your camera can support a 4G card. Some don't support than 2GB. if it supports, re-insert the card.
PS. If you have a card reader. Formatting once from your computer can help.
Jan 15, 2009 | Kingston 4GB Secure Digital High Capacity...
Cannot read Kingston 2GB SD card on my computer
Dear,
All just try this trick
Connect your phone to PC and try to acces the card on PC. Now format the card but, take the backup of data before formatting the card.
Regards,
Rakesh Kumar
May 19, 2008 | Kingston 2GB Secure Digital Memory Card
Computers & Internet Logo
3,347 people viewed this question
David Payne
David Payne
