Question about Radio Communications
Uniden bc95xlt scanner LOCKOUT REMOVAL
I AM TRYING TO REMOVE ALL THE LOCKOUTS ON MY RADIO CHANNELS-HOW DO I REMOVE THEM?
  • millions134 Dec 03, 2008
    EVERYTIME I HOLD DOWN THE (HOLD) BUTTON THE CHANNELS KEEP ADVANCING. IF I JUST PRESS AND RELEASE THE HOLD BUTTON THEN PRESS FUNCTION AND L/O EVEN FOR A WHILE-NOTHING HAPPENS!
    IF YOU CAN THINK OF ANYTHING ELSE-PLS LET ME KNOW.
    THANKS
  • 90 Answers
To remove the lockout from a channel, manually select the channel, then press Func + L/O.
L/O disappears.
To unlock all channels in the banks that are turned on, press Hold to stop scanning, then press Func
and press and hold L/O until the scanner beeps twice.
Posted on Dec 03, 2008
  • David Eisenberg
    David Eisenberg Dec 03, 2008
    I don't know why it doesn't work for you. I just tried it on a BC95XLT & was able to unlock individual channels as well as all of those that had been locked out.
I have a Uniden bc95xlt scanner! it is less than 1 yr. old. it will lock on to a channel and not unlock to continue scanning. I can't find my paperwork to prove age of scanner! Pls. Help!
Hi Jan,
It sounds to me as if your scanner is locking on to a 'BIRDIE', which is an internally generated frequency in the scanner, all scanners have this by default, your user manual usually has a page, near the back of the manual, with known 'birdies', and there a lots.
When your scanner locks onto a 'BIRDIE', which is a frequency with no voice audio, the best thing to do is press Lockout button, during the scan, your scanner will, if there is no other problem with it, continue to scan, until it finds another 'BIRDIE', then you do the same thing as I've described, until you've locked out all the 'BIRDIES'.
I hope this info was useful.
Cheers,
Peter.
Jan 23, 2013 | Uniden Bc95xlt 200 Channel Scanner
Stuck in lockout mode
radio shack pro 97 scanning receiver,
Jul 17, 2012 | Uniden BC60XLT-1 Handheld Scanner
My scanner was woking fine untill i hit a button by mistake and now it wont scan through the channels ... i dont know what button i pushed!
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.try this the channels could be locked
Jan 22, 2011 | Uniden BC898T Base Scanner
I NNEED TO KNOW HOW TO PROGRAM MY UNIDEN BC95XLT SCANNER, I CANT EVEN FIND THE MANUAL ON LINE
You can download and print your scanner manual, at no cost, here:
http://www.uniden.com/pdf/BC95XLTom.pdf
Bill B.
Listening in since the 60's
Jan 16, 2011 | Uniden BC92XLT Handheld Scanner
How do you change/enter a frequency? im trying to listen the local police radio but i dont know how to work this scanner.
The BC95XLT is fairly simple to program, and you can find detailed instructions in the factory manual which you can download and print here at no cost:
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Listening since the 60's
Sep 20, 2010 | Uniden BC-95 XLT Scanner
Can't unlock channels. i push func + lockout but nothing happens
To remove lockout on all channels, do the following:
Press scan
Turn on all banks that you want to clear lockout on.
Press hold.
Press func
Press AND HOLD L/O until the radio beeps twice.
Feb 24, 2010 | Uniden BC92XLT Handheld Scanner
Have older model mobile unit-is locked on channel 1 will not scan-no buttons work- channel 1 does receive transmissions-squelch works-???
I couldn't find a RESET procedure for this model, but it's possible that all channels above #1 have been locked out. Try pressing MANUAL, then press and hold LOCKOUT for more than 2 seconds. Two beeps will confirm release of the lockouts. No guarantees, but I hope this clears your problem.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC860XLTom.pdf
Bill B
Feb 17, 2010 | Radio Communications
Have l/o for all channels. but can't get them
To unlock a channel, power the scanner ON, then press MAN, the channel number, MAN again, and then L/O. Lockout will also show if no frequency is programmed into a channel, and programming a frequency will automatically release the lockout.
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, visit:
BillB
Jan 24, 2010 | Uniden BC60XLT-1 Handheld Scanner
Lockout message
Uniden has a webpage with a free manual pdf download for your scanner.
You'll be able to get the manual HERE The link is upper right side of page..
If all your channels are locked out, press and hold the l/o button for at least 2 seconds, you'll hear 2 beeps and that should unlock them.
May 23, 2009 | Uniden BC120XLT Handheld Scanner
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
Radio Communications Logo
481 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
