Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
No picture on half of screen
Everything seems to be working fine except there is only lower half the picture and a bright line in the middle. This tv is about 4-5 yrs old and i worry that the repair cost will be equivalent to the replacement cost. I am wondering if i can fix it myself if i know what part to replace. Thanks tom
  • tom layton Feb 01, 2007
    Thanks tvtek!
    Would you know of good place in the web to find this part?
    I'll post the results in a week or two assuming I survive the electrocutions :)
    President:
  • 1,284 Answers
The vertical output IC is most likely the cause. On a 27 inch TV the generic part number is AN5522 the location number ic IC561. Be careful of dangerous voltages within the TV powered on or off.
Posted on Feb 01, 2007
  • Don
    Don Feb 02, 2007
    Here you go.
    http://www.partstore.com/PartNumberSearc...
    Right to the page and to the part you most likely need.
  • Don
    Don Mar 01, 2007
    I wonder if all turned out ok on the original posters TV now.
    Sergeant:
    Champion:
  • 267 Answers
SINCE YOU HAVE HALF THE PICTURE THE VERTICAL IC IS STILL WORKING. THE PUMP UP CAPACITOR AND THE OTHER ELECTOLITIC CAPACITOR IN VERTICAL CIRCUIT MAY BE BAD. THE CAPACITOR IS USUALLY 100UF OR 220 UF AT 35V REPAIR EST. IS $135.00
30 YR SERVICER APGONZO
Posted on Jan 12, 2009
I have the exact same TV and the very same problem! (sounds like a SONY bug to me!) Curious of the original poster (Layton) had tried the suggestions and which one fixed the problem? Thanks! ALSO, as a caution, I googled replacing the electrolytic capacitors and it can be very dangerous if you touch certain wires, can cause cardiac arrest according to the site http://www.nmr.mgh.harvard.edu/~reese/electrolytics/index.html ... SO PLEASE BE CAREFUL!
Posted on Feb 08, 2007
  • 105 Answers
I DON'T THINK THAT VERTICAL OUT-PUT IC IS FAULTY BUT DECOUPLING ELECTROLYTIC CAPACITORS ARE. JUST REPLACE ALL ELECTROLATIC CAPACITORS IN VERTICAL SECTION AND I HOPE PROBLEM IS SOLVED.99% OF TIME THIS PROBLEM COMES BECAUSE OF THAT.IF VERTICAL IC IS FAULTY THEN YOU WILL GET A SINGLE HORZONTAL LINE AND SUPPLY RESISTOR OF THAT IC WILL BLOW OPEN AND TV WILL GO IN PROTECTION MODE.
Posted on Feb 06, 2007
Thank you kindly, tvtek!
SOURCE:
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
Hisense TV - right half is blue
change your tcon board and you will be fine
Oct 06, 2017 | Televison & Video
No picture in upper half of screen, normal at bottom
Could be something as simple as a bad contact on one of the deflection yokes or other coils on the cathode ray tube - check the contacts on the circuit board where these coils are connected, resolder the pins or wires if the contact is bad, also check connector pins for any dirt or oxydation and clean if necessary.
Read more about this kind of problem at:
http://www.repairfaq.org/sam/tvfaq.htm#tvpopco
Hope this helps somewhat.
regards
3rq8 (Triarcuate)
Sep 04, 2009 | RCA 20F512T 20" TV
SAMSUNG LCD TV FAULT
samsung lcd tv 40inch modle .LA 40c 53F1R negitve video and brightness high plz send id mirzarashidbaig126@yahoo.com
Dec 12, 2008 | Televison & Video
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
