Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Switch is not working
My off and on switch is not working if you hold down it will run otherwise when you take finger off it stops. please help i love this vaccum.
thank you vickie gamble
  • 105 Answers
Had same kind of problem. had to have switch replaced.
if you or someone you know can repair it you can order part online and fix it and save or take it to a vacuum repair center.
google replacement parts for your model there are several.
you can try sears parts direct they carry the switch.
Posted on Dec 03, 2008
When I PUSH THE RED BUTTON TO TURN ON THE DYSON IT RUNS AND HAS SUCTION AS LONG AS I HOLD DOWN THE BUTTON--wHEN I TAKE MY FINGER OFF OF THE BUTTON THE DYSON STOPS RUNNING
Sorry to hear you're having difficulties with your DC07. If the on/off switch doesn't seem to be working correctly, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Jul 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
My dyson slim has good suction to the wand but won't switch to the floor suction... Help..
Flip the vaccum upside down and if there is a seperate suction hole for the floor accessory try to see if it is clogged. Otherwise a little belt may have slipped of which makes the brissles go around.
Aug 05, 2010 | Dyson Vacuums
The switch will not stay on
Hi your switch is either dirty or worn out. if you can get to it and use compressed air to dust it's insides, it may work again, other wise you will have to replace it. J.
Jul 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Will not stay running
you have a bad switch.if you have any spray contact cleaner you can spray it in the switch and work the switch a few times and see if it works if not you need to get a new switch.you can get the switch at any vacuum repair shop.if you would like call all-type vacuum and janitorial supply and ask for lisa.she can help you.tell her pete advised you to call.contact cleaner you can get at radio shack.i hope i have been of some help to you.please leave feedback
Jan 12, 2009 | Bissell 6594 PowerForce Bagless Upright...
Rainbow E Series
You are supposed to use the hard surface cleaner solution and mix with water. Vaccum the hard surface first, then dip the hard surface attachement in the mixture (while machine is off. otherwise you will just **** up all the mixture! :) ) turn on the machine and "mop" away!! I love it!!
Jun 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Door stopper stuck in vaccum
I would first check down by the brush roll, take off the plate so you can get to the inlet to see if it stuck there, could be in the hose or the bag tube. Could be that it damaged the motor fan, you have to remove the motor to check it. If You had listed the model number, it would have been alot of help.
Dec 25, 2007 | Vacuums
Rainbow vaccum
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
Ifix@shentel.net
Oct 18, 2007 | Rainbow 75th Anniversary Canister Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
