Question about Onkyo TX-SR705 Receiver
Dialog track not playing for a 5.1 DVD
Connecting a DVD player with Component Video, and Coax Digital Audio to tx-sr705. Playing a 5.1 DVD with 5.1 speaker configuration. Video is fine. Audio is not. Center speaker has no sound. Dialog track of video only present when setting on "stereo", "all channel stereo", and "mono movie". Dialog track is missing when setting on "Dolbe D", "THx", and several other modes that generate 5.1 sound. It appears that all the music, ambient & background sounds and effects are present when setting at modes for 5.1.
  • 10 more comments
  • thammack305 Dec 03, 2008
    Solution #1 is not the answer. All speaker cables are connected correctly. In "all channel stereo" mode, all speakers (except the center speaker) are active with full audio.
    The problem is within the AV itself.
    Any other possibilities?
    The two solutions that have been posted to this problem are not responsive. Speaker cables are secure, the configuration is correct, the firmware is current (according to the AVS postings).
    Is there any input about hardware malfunction that could cause the described results?
    To clarify (possibly):
    The "central" speaker is the central small speaker in 5.1, not a bass speaker. The speaker works fine in another set-up, but is silent in the SR705 set-up. This makes me think that the receiver is malfunctioning.
    The "front" and "surround" speakers are configured correctly in the SR705 set-up. The audio is correct when the listening mode in the 705 is set for "stereo" or "all channel stereo". But when the listening mode is set for any of the 5.1 options, the dialog channel of the 5.1 coding is missing. Only the ambient sound and sound effects are present. The sound effects (eg. a passing auto) move from speaker to speaker correctly. This is true for both Dolby and DTS coding in the DVD.
    This is my first experience that shows the sound in 5.1 coding to be seperated into components. But I am sure that there are many other things I don't know.
    The speakers are connected to the (amplified) output of the Onkyo TX-SR705 AVR. And the manual "speaker configuration" setting is correct for the speakers.
    The AVR is connected to a PC monitor with an HDMI cable. The "HDMI audio" setting is "OFF" (part of the TX-SR705 setup).
    The AVR is not connected to a PC. Is connected via HDMI to a video monitor.
    No change with "HDMI audio: ON".
    Any other ideas?
    I have manually setup the speaker configuration--several times.
    I have used several source DVDs, each with Dolby 5.1 coding, and one with DTS coding. All with the same result.
    The setup is built around an Onkyo TX-SR705 receiver. Sony DVR connected to the AVR with component video and digital coax cable. LCD monitor connected via an HDMI cable with audio "off". Polk Monitor speakers connected with Belden speaker wire, connections checked and rechecked--5.1 configuration.
    Other sources connected to the AVR include phono & cd, both work fine in 2.1 stereo.
    I mis-wrote in the last comment. The source is a Sony DVD, not a DVR.
  • thammack305 Dec 04, 2008
    To Benimur:
    I have played the DVD "barefoot", and the center speaker remains dead. Your suggestion re. the center speaker is apparently correct. How can I accept your speaker solution and continue with the lost dialog problem without repeating all the discussion to date? Obviously I have posed two problems.
    Solution helpful for one of the two problems described. I originally thought that the problem statement was a single issue. But now believe that there are two problems. Will re-state the second problem and re-submit to the service.
  • 4,234 Answers
Unfortunately without "surround" processing, the center speaker will not work at all. It sounds like there is a problem with the center channel amp which is part of the receiver. This should be a single amp IC attached to the heatsink. There should be a "test" moe that will send white noise to each speaker in sequence. Try that. If that results in no sound to the center, it pretty much concludes that the center amp needs to be repaired. The part cost for this should be around $25.
Dan
Posted on Dec 04, 2008
  • 586 Answers
    Please check first the "TEST TONE" if in test mode the speaker not work then there must be a problem which tends to some thing malfunctioning.
THanks
    Sergeant:
    Champion:
  • 283 Answers
Hi, please dont rate me if this could not fix your problem. There is to possible ways that causes your problem:1st is a wiring connections. Check well your wire if properly installed.If you have multitester then please check the continuity of your wire. 2nd maybe will be on the settings. Check the wire of your audio input/output then press the settings where you set up it.Thank you...
  • 1,800 Answers
Ok.
most likely the problem occurs when :
options and parameters r not "setting up" well.
also u shud realize that some movies doesnt support even the 5.1.
anyway just make sure of the settings.
Posted on Dec 03, 2008
  • Jalal Sordo
    Jalal Sordo Dec 03, 2008
    are u usic a home cinema compenets plz tell me what is the usints that u r working on so we can get a good set up and wiring.
  • 4,806 Answers
Can i just clarify something? what are you connecting the DVD player up to? a TV or a PC?
  • Lee Hodgson
    Lee Hodgson Dec 03, 2008
    LOL, if your trying to listen to the audio via the PC then i had the same problem!!! what your computer needs are the latest codecs!!! get XP codec pack here (it works just as good with vista):
    http://www.xpcodecpack.com/download
    and you also want DIVX player for them codecs too, get the player here:
    http://www.divx.com/divx/windows/downloa...
    hope this resolves the problem for you
    regards
  • Lee Hodgson
    try it with the HDMI settings ON,
    Master:
  • 474 Answers
Hey, i had similar problems myslef way back when with the exact same issue and im trying to remember the cause.
First, it is most likely with the setting with the AMP or whatever your using to split the channels for surround sound. Judging that the DVD is set to 5.1 surround sound, thenim guessing its the AMP. usually there is a configuration setting that lets you change from DIGITAl to ANOLOGUE, Stero to Mono or Surround through DOlby digital.
How is the VDVD player connected to the speakers. an AMP, or one of theos suround sound speaker Kits that just plug on little jack into it and instant sound comes form it and the Subwoofer acts as the central point for the other speakers?
Let me know so i can narrow down the posibilities. While i wait for you, i will go mess with mine and try and remember the exact cause.
  • Onkyo Master
  • 19,396 Answers
If the the center speaker never works, then there is a fault.
If by "the center speaker" you mean a central small speaker in a 5.1, than the speaker is faulty or the cable is badly connected. More likely a bad wiring.
If by center speaker you mean the bass unit (central woofer) then there again that is probably a fault. Once again this unit is sopposed to produce sound even in mono, or two speakers stereo.
When you switch to 5.1 mode, you use all the speakers the same as in mono, or 2.1 stereo mode, only the sound is distributed in a different way.
Usually, when one of the speakers never work, that means that there is a problem with wiring, or with audio system and speakers.
The chance that this is a faulty DVD output is quite remote.
Test the audio system by connecting to a different device. If all speakers work, check wirings, if wirings are ok, then you can say that the DVD has a fault.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, post describe several possibilities:
  1. configuration/settings glitch;
  2. firmware glitch;
  3. hardware fault.
  • Assuming that it is a configuration/settings glitch, a reset should undo any error and restore unit to factory default settings. This could be accomplished by:
  1. power on;
  2. press and hold VCR/DVR button;
  3. press STANDBY/ON button;
  4. "Clear" should be displayed;
  5. unit will revert to Standby mode.
  • For a firmware problem, you can always have it updated. Pls reference this page for additional insights.
  • Should it be a hardware fault, then a service manual would serve as guide for the checks and diagnostic procedures.
If the above solution has merit, pls click on my "Ask Me" to explore additional options, postback how things turned up or should you need additional information.
Good luck and Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role Dec 04, 2008
    Have you tried playing "barefoot", no Dolby processing. If output (sound) is still missing from one or a number of speakers, then it is hardware, most likely one or more of the amplifiers. On the otherhand, if the sound is present, then it would be the Dolby processor board.
  • Louie  Role
    Hi again,
    Any updates or developments so far?
  • Louie  Role
    I hope you would be able to view this comment...
    One down
    , amplifier for center speaker of the Onkyo TX-SR705 is defective.
    2nd issue, Dialog track is missing when setting on "Dolb D", "THx", and several other modes that generate 5.1 sound. Again the Center Speaker. Pls see p.20 of the manual:
    • "This speaker enhances the front left and right speakers, making sound movements distinct and providing a full sound image. In movies it’s used mainly for dialog."
    Genius:
  • 1,268 Answers
Speaker cables and connectors might have been jammed, make sure they are connected to designated ports. Make sure the type of cable supported or you can try to use a high end type of cable for the video and sound.
    Genius:
  • 1,847 Answers
Swap the audio jacks and then try.
  • Legin Varghese
    Legin Varghese Dec 03, 2008
    Try a different DVD which have worked in the past. and try playing the dvd on normal stereo conditional, and if one of the channel is missing swap the jack and check.
Pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Pioneer Audio Players & Recorders
How can I listen to the iTunes music video on my MP3 players with audio track only? It's better if someone can help me save the M4V videos as MP3 format.
Hi, I know TunesKit DRM Media Converter iTunes DRM Removal for Mac Remove DRM from iTunes Rentals and Purchases on... is a good choice for your problem. It will competely remove the DRM protection from iTunes purchased and rental videos and convert iTunes M4V to common MP3, M4A, AAC etc. format with lossless quality. You can refer to the tutorial of Best Solutions to Extract Audio from iTunes M4V Videos
Jan 07, 2017 | Sony Audio Players & Recorders
How to disable video while playing mp3's ?
Mp3's do not contain video. Mp3 files are audio only. You are likely looking at another type of file which is a video file. Online Virus Removal 39 99 Enter To Win Free PC Clean and Tune 39 99 Value
Jan 12, 2015 | Audio Players & Recorders
MY PANASONIC 5CD STEREO SKIPS WHILE PLAYING CD'S I HAVE USED A HEAD CLEANER AND IT STILL DIDN'T WORK.I HATE TO DISCARD IT.
The laser pick-up unit fault [weak]. You have to replace it with a new one of similar number. Contact any service technician. To replace this part, you have to take out the whole mechanism from the system; and this is a skilled work.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Electro help
Dec 26, 2014 | Audio Players & Recorders
Why toshiba l305-s5945 media player not playing cd
Possibly it is in the wrong format. Download vlc media player, that will play anything and will let you know if the DVD player is faulty or bot.
Jun 14, 2014 | Audio Players & Recorders
My aftermarket radio won't play any music out but when I put my stock radio back in everything works fine the aftermarket radio worked for a few weeks but then it stopped playing music out recently Any...
think the amp may have blown this is the problem with some after market radio's with the same wiring code as yours. best just ot get the radio you want and buy the adapter kit for it.
Mar 23, 2014 | Audio Players & Recorders
S9 malfunctioning
does the other buttons work play pause
if not then your phone most likely does not have
Audio Video Remote Control bluetooth Profile (AVRCP)
Aug 12, 2009 | Motorola Mobility S9 Headphones
Onkyo TX-SR705 Receiver Logo
475 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
