Question about Amana Kitchen Ranges
1) Right rear burner electric spark always arcs no matter which of the four gas knobs I turn. 2) Right front burner electric spark only works (arcs) when left two burners panel is unplugged or removed.
  • Anonymous Mar 15, 2014
    rear burner arced and knocked the breaker and with the burner unplugged and the breaker on the burner lamp stayes on
Sure. Once we realized that you'd charge a fee, we went to our local brick and mortar appliance repair store and got the info needed for free. What happened to free advice?
M
Posted on Dec 03, 2008
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Front right burner knob will not activate the sparking. No clicking or spark. The other three knobs all activate the spark. I have been turning the gas on to the front right burner and then activating...
You are correct, on most Kitchen Aid units the switches come as an assembly of all 4 with the wiring, I would have to have your exact model number to be sure but most often you cannot replace just the one switch.
May 07, 2010 | KitchenAid Kitchen Ranges
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Ticking sound does not go off even after knob is turned to high or medium
A lot of questions on this site but very few answers. I have the same problem. After an overflow from a pot, the 2 front burners now won't light one rear one lights but won't stop sparking and the littlest one is fine.
Mar 30, 2008 | GE 30 in. Profile JGP933SEFSS Gas Cooktop
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
Kitchen Ranges Logo
96 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
