Question about Garmin Nuvi 350 Car GPS Receiver
Cannot update garmin nuvi 360
When i try to download an update to my garmin 360 a box comes up saying " media is write protected" so i cannot put any updates onto it.
I am using Windows XP home sp4 .
I have used a friends computer and it will take the downloads.
  • shacham Jan 10, 2009
    i have the same issue with nuvi200w. Garmin supprt could not help me ....yet.
    Can anyone help?
5 Suggested Answers
SOURCE: GArmin Nuvi 360 - bluetooth not working right
I had the same issue, prior to downloading the update. So I downloaded the update and when it asks you if you want to check for further updates for this device, select yes. There, you'll find the bluetooth update. After I installed it, the device seemed to work perfectly. My garmin nuvi 360 has yet to disconnect from my phone, and it's been several hours since I updated.
Best of luck to you!
jonathan
Posted on Apr 24, 2008
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
wwjdcgh
  • 114 Answers
SOURCE: free update for nuvi 200
you need to go to garmin web site register it and they will give you the free download there.
Posted on Mar 26, 2009
  • 6 Answers
SOURCE: Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Posted on Jun 03, 2009
SOURCE: need free updates for my garmin nuvi 200
You didn't say how long you've had your device, but if you haven't registered your device at Garmin.com yet, go do that and they will then offer you a free upgrade.
Other than that, I don't think you'll find anything free. The next best thing is to buy the "nüMaps Lifetime™". I felt this was the best deal they have.
Posted on Jul 28, 2009
The garmin nuvi 1300 series comes on and then says loading maps and does it over and over and will not load maps
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
When i power it on it says loading maps and will not do anything
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Feb 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 360 wont unlock maps
Master reset is after you turn on the GPS put a finger on the left lower corner rightaway and then keep the finger there, wait until it shows up the "Do you really want to start up in maintainance mode"
You are not able to use others nuvi's map on your nuvi 360, as each map must match with the GPS unit ID, to find out your GPS's unit ID, go to "Setting" tab on "System", tab on " About"
Mar 29, 2009 | Garmin NUVI 360 GPS Receiver
Download update problem
Are you trying to update a Nuvi that already has European maps installed or are you trying to install European maps into a Nuvi that does not already have them?
If it's a map update, are you getting the error when you download the update to pc, or when you are trying to install the update to the Nuvi?
When I install US map updates into a streetpilot or Nuvi, it typically ends with a download error but the maps do in fact get updated and the new software versions are shown in the setup menus.
The Garmin rep I spoke with says that is normal.
If you are in the United States, I can get you maps, updates, and even install them for you if you wish.
Feel free to shoot me a message if you're interested.
Jan 07, 2009 | Garmin Nuvi 660 GPS Receiver
Aug 13, 2008 | Garmin nuvi 350 GPS Receiver
I have a NUVI 360 and put on the 2009 updates, however I can't open the file as windows needs to know the program before it can open file. File number NAVW32.EXE 24F56911.PF
Hey mgpeplow,
In order for your Nuvi 360 to Work with the latest 2009 Update, you will have to get the new software for the Nuvi. Visit their website, and it will have a download for the latest software. Install it and you should be all set.
If this helps at all, please rate this a FixYa. - Evolution
Jul 16, 2008 | Garmin GPS
Garmin nuvi 360
Have you tried another usb slot....and don't use a usb hub!
Jul 11, 2008 | Garmin nuvi 350 GPS Receiver
Wow, as soon as I got my nuvi 360 I turned the Bluetooth off. I then updated to 4.40 and the bluetooth SW version is now 0.00 and i cant even enable the bluetooth again. I think we have the same problem. I wish I could help but I am in the same boat.
Dec 24, 2007 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 350 Car GPS Receiver Logo
198 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
