Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 Washer pump issue
My washer won't pump out rinse water. The pump makes clicking popping noises, but won't pump. I emptied the water, cleaned the filter, and even replaced the pump with new pump. New pump makes same exact noise. Drain line appears to be clean. Maybe needs new control board? Board is more expensive so I would like to know that is problem before I spend $130 on new board.
  • Bosch Master
  • 3,463 Answers
If the pump is working then you will not need a new board..
Remove the pump from the m/c, connect live and neutral supply to the pump, it should run.
If it does then your problem could be an internal blockage in the m/c.
Hope this helps
Posted on Dec 03, 2008
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Terrible noise when draining
Possibly more hair pins in the pump or possible the pump is faulty check that the propellor is not loose if so a new pump is needed.
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Suds or blocked pump for bosch washer
If suds put epsom salts in dispenser on rinse cycle,
this kills the suds instantly.most likely to be pump though.
Mar 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
184 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
