Question about Apple iBook Mac Notebook
Model A1005 mac ibook
My mac ibook hard drive decided to make noise and give up. i replaced the bad drive but was unable to get any OS information put on the new one and unfortunately i do not have the original recovery CD, can you provide information on how i can get a recovery CD and so i can get the system up and running?
  • JDTec
    JDTec May 11, 2010
    You would have to either borrow a set of cd's or purchase the Mac OS from Best Buys or the Apple store.
    Sergeant:
  • Apple Expert
  • 250 Answers
When you say recovery disk I assume you mean the main OS disk. A recovery disk on a mac generally is one you would make as a back up. Depending on the OS you used you would need to get a new one. These you can pick up from eBay pretty cheaply, both OS9 and OSX10.4.
All the best
Sean
PiDigital
Posted on Dec 16, 2008
Need manual for Apple iBook G3 12" 800MHz model no A1005
You might want to try this? I am not sure if it is the same as your machine.
http://manuals.info.apple.com/en_US/PowerBook_G3_Users_Manual.pdf
Try this page and keep looking in this area if the one above is not the same model.
http://support.apple.com/manuals/#G3%2012"%20user%20manual
Good luck hope this helps.
Jan 15, 2013 | Apple iBook G3 800MHz 256mb 15GB CD Drive...
When you power on the (apple) or (mac os x) iBook model#A1005 ( NTBOE004010) a screen comes on and ask for username and password. i purchased this computer ibook second hand so how do i proceed from here...
Congratulations on your new computer! What you need to do is reinstall the operating system, after wiping the computer:
  1. Turn the Mac on and insert the restoration disk that came with it (If you don't have one then you'll need to get one, try ebay or amazon, or an Apple store).
  2. Turn the Mac off with the disk still in
  3. Re-boot it, holding down the C key. This will boot up from the CD, and hopefully you'll be able to re-install Mac OS X, which will give you a working, clean machine.
When you get to step 3, you should have a menu bar at the top. Select Utilities -> Disk Utility. Select the computer's hard drive, and 'Erase'. Call the new partition whatever you like, but make sure it uses Mac OS Journaled Extended file system. Follow the instructions and you'll have a machine like new!
If you don't already have an install disk, watch out - you can only install Mac OS up to Mac OS 10.5 on your iBook. Don't buy a 10.6 (Snow leopard) disk, as it won't install!
Hope that helped, good luck!
Jan 09, 2011 | Apple Computers & Internet
Ibook a1005 won't start .My daughter had a ipod touch from China plugged in- it shut off and won't attemt to start.The battery is full and has a new power cord.Is there a reset somewhere?
Ok, there is something you can do to try to fix this. You need to reset the power management circuits - it's very simple, just follow these instructions:
  1. Firstly, try a less drastic approach - hold down the power button for 5-10 seconds. This may succeed in starting up your iBook.
  2. If that doesn't work, you need to reset the power management. Unfortunately, there are plenty of different models of iBook and many have different ways of resetting. You'll need to consult this guide to decide which way will work for your model.
If you need a hand figuring out what type iBook you have, just ask, and I can guide you through figuring it out. Same goes if you don't understand some of the instructions.
Dec 28, 2010 | Apple iBook Mac Notebook
I have a apple ibook g3 model m6497. i know its older. my laptop will not boot up. grey screen with apple but no loading spinning icon. when i hold down the options button it jumps into a blue screen with...
Most likely your Hard drive has gone bad. Hard Drives typically last anywhere from 3-5 years.The grey screen with the apple signifies that it found a Hard drive with your OS (Software) installed but it can't seem to go past that because the Hard Drive may be failing.
Dec 13, 2010 | Apple iBook G3 Mac Notebook
I was trying to install Mac OS X 10.3 on my G3 iBook, it did not work, and now neither does the iBook.
It sounds like you have a hardware issue of some sort - likely a bad hard drive, due to age. I would suggest taking the laptop to a repair shop (don't bother with the Apple Store, they'll tell you to buy a new laptop or just turn you away). Best of luck!
Nov 09, 2009 | Apple iBook G3 Mac Notebook
A1005 Battery and power supply fine - but not starting
A1005 is an inexact marketing identifier covering pretty much the entire line of G3 iBooks.
Complete failure to start -- unless it is caused by something trivial like a broken start button -- without any startup or error tones, points to basic logic board failure. A machine this stone dead for no apparent reason is unlikely to be revived, and almost certainly not by third-world techs who don't know Macs. It is debatably cost-effective to resuscitate a sub-GHz G3 iBook from such a failure, compared to replacing the unit with another new or used Mac. The drive in the old Mac can be extracted so as to preserve your data, and can be inserted into an external USB or FireWire case to be accessible to a new Mac.
Oct 10, 2009 | Apple iBook Mac Notebook
My ibook wont start up i power it up and blank screen and making a bit loud noise while its on...is there anyway i can bypass this and get to my start up menu?
"Loud noise" implies either the fans, the hard drive, or the optical drive, as those are all the moving parts in an iBook. If it won't start up, I'm guessing you have a bad hard drive. If so, you can revive your machine with a new hard drive, but your old files are probably toast unless you have backups.
Oct 03, 2009 | Apple iBook G4 Mac Notebook
I-BOOK A1005 Monitor dead....
this should be because the parts inside doesnt fit properly
Jul 03, 2009 | Apple iBook Mac Notebook
I-BOOK A1005 bootup problem
if its a pale blue screen with a really old looking graphic of an apple logo then that means it is not finding a bootable device
Jul 02, 2009 | Apple iBook Mac Notebook
Replaced HD on ibook Clamshell, now can't boot
The Clamshell iBook 366 doesn't officially support Tiger, but can usually be installed using 'XPostFacto'. (You can get it here http://eshop.macsales.com/OSXCenter/XPostFacto/
It's open source software but you still might find some aspects of Tiger don't work.
Jan 12, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Apple iBook Mac Notebook Logo
575 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
