Question about Maytag MGR5770 Gas Kitchen Range
STOVE IS SHOWING F-3 AND OVEN WILL NOT GO ON.
  • nanbo368 Dec 07, 2008
    Thank you Joe. I'd like to buy the part. Do you know the part number and where can I get it?
  • 41 Answers
Most f-3 error codes are for the oven sensor. you sensor is probably bad and needs to be replaced. Joe
Posted on Dec 03, 2008
  • rbnsn6 Dec 08, 2008
    you would need to get it from an appliance part store or order it online. there are several appliance parts stores online if you don't have one locally. just use your model number and they will be able to get you the part you need. Joe
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
How to fix kenmore f 3 code?
f3 code is the code for the oven temperture sensor that control the oven temperture need be replace ok
Dec 13, 2017 | Washing Machines
I have a Kenmore stove. Early this morning my daughter made a pizza and then a little while later my son made eggs. The ERC pad is showing 5. (5 dot is what it's showing) the oven nor the broiler work, the...
try to isloate the power to the stove. at the fuse or trip etc.
leave it for a couple of minutes and then switch power back on.
this may clear the problem.
I hope this was useful
Jan 11, 2011 | Kenmore Kitchen Ranges
Y stove is showing F2...What do I do to fix it?
F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Sep 29, 2010 | Kenmore Kitchen Ranges
I have a F3 showing on my stove , which according to my booklet is a fault sign to disconneci and call a repair service
Usually F-3 is a bad oven sensor which is easy to change. It is located in the oven section and it is the rod coming through into the oven that measures temps.. You should be able to change this out yourself. Hope this helps.
May 31, 2010 | Crosley CE35100AA Electric Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Off button doesen't shut off oven
You will probably have to replace the electronic range control.
Jan 03, 2009 | KitchenAid KESC307 Electric Kitchen Range
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
Maytag MGR5770 Gas Kitchen Range Logo
67 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
