Format a seagate drive st96812a for use in rocketfish enclosure kit RF-HD25
    Sergeant:
  • 237 Answers
Formatting a Secondary Hard Drive
Step1
Right-Click on the “My Computer” icon either on your desktop or in the Start Menu and select “Manage.”
Step2
A new window titled “Computer Management” comes up. Select “Storage” from the left hand side by clicking it once, then select “Disk Management(local)” from the right side by double-clicking it.
Step3
Now in the lower part of the main frame (right side) of the window you should see a nice visual of all your hard drives. Each line is a different drive. Each box on a line (with a colored bar at the top and a size displayed in MB or GB) is a partition on the drive. Partitions are separations of space on a drive. Unless you are doing something specific that requires multiple partitions, you only want one partition per drive.
Step4
First you must delete any existing partitions on the drive you are going to format. Do this by right-clicking on the partition's box and selecting “Delete Partition...” Since you already know that you will be deleting everything on the drive, and have already backed everything up, you can safely say yes to any warning the computer presents you with.
Step5
If there are multiple partitions make sure you have saved everything off them since they might each have different drive letters (i.e. “D:” or “F:”). Then repeat the above step for each of them. If you only want to format one partition that is OK and you can continue to the next step without deleting the other partitions.
Step6
The box for the drive to be formatted should now have a black bar at the top of it and should say “Unallocated” under its size (see picture). Right click on it and select “New Partition...” The New Partition Wizard comes up.
Step7
In the New Partition Wizard click next. On the next page make sure “Primary Partition” is selected and click next. Now make the size equal to the maximum (it should already be set to it), and click next again. On the next page the computer will automatically choose the first available drive letter for the new drive. However, if you like you can choose another drive letter from the drop-down menu, and then click next.
Step8
Finally the New Partition Wizard asks if you would like to format the new partition and if so what format. Choose “NTFS” as it is faster and more secure. Leave the “Allocation unit size” as “Default.” In the “Volume label” field enter whatever name you want the drive to have. Simple is better. Avoid using spaces. Lastly, if the drive is brand new and has never been used before check the “Perform a quick format” box. If the drive has been used before leave this box unchecked. Leave the “Enable file and folder compression” box unchecked and click next. Then on the next page click finish.
Step9
The wizard will now spend a little while formatting the drive. On old or large drives this may take a while. Do not close the “Computer Management” window until it finishes. You will know it is done when the word under the size of the drive changes from “Formatting” to “Healthy” and the name and drive letter you chose for the new drive show up. After it is finished you can proceed to use your newly formatted drive.
Posted on Dec 02, 2008
I have the rocketfish hard drive enclosure and when i started to use it on the my MacPro it was working fine then it just stopped working and stopped being recognized.
The internal connection of the hard drive has probably become dislodged. Open it up and reconnect it firmly. If that does not resolve the issue the drive may simple have died (the hard drive, not the enclosure)
Apr 22, 2011 | Rocketfish 25" EIDE ATA HARD DRIVE...
Can I boot off the drive from/in the Rocketfish drive; with the operation system that's installed on such as Win XP?
Yes but can be difficult. First you need to make sure your motherboard can boot brom a USB connection. If so then you have to format and install an operating system. Linux would be your best bet to try it out as that particualr operating system is free and has been developed with unusual installations in mind. I would suggest ubuntu
Apr 20, 2011 | Rocketfish RFAHD25 Sata 25 Hard Drive...
I am trying to insert my toshiba 80 gig mk8025 gas hard drive into a rocket fish 2.5 hard drive enclosure kit but it is like the pins do not match??
You may just have the drive upside-down.
flip it over and it should fit...
Unless of course you got the SATA rocketfish, because your drive is PATA (ATA-6)
this is actually more likely the case!
Apr 11, 2011 | Toshiba MK8025GAS 80 GB Hard Drive
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
How do I install rocketfish camera RF NBWEB without a disk?
Windows drivers are at
http://www.rocketfishproducts.com/skins/skin_1/Topics/Drivers/RF-Webcam.zip
Mac drivers are at
http://www.rocketfishproducts.com/skins/skin_1/Topics/Drivers/RF-NBCAM-Mac.zip
Feb 08, 2010 | Labtec Rocketfish Webcam
Device not detected
try to see if you computer is giving you the option to search online, it should find it and you can download it.
Aug 15, 2009 | Computers & Internet
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
