it helped me to get in but i get harddisk password now is ant thing i can do for thisit helped me to get in but i get harddisk password now is ant thing i can do for this
You can't post conmments that contain an email address.
Is it an aspire ?
Resetting the CMOS password on an Acer Aspire laptop is much
more difficult than resetting the password on a desktop.
Disassembly steps vary from model to model, but on most
models, you'll have to take apart the computer to access the CMOS battery.
Don't take apart the notebook if you don't have experience
disassembling PCs.
After turning off the computer and disconnecting the AC
adapter, take out the battery (different from the CMOS battery).
All visible screws must then be removed from the bottom of
the notebook.
Remove all components stored to their separate compartments
on the base of the notebook.
Turn over and open the PC. Lift up the switch cover and
remove the screws securing the keyboard to the PC, if any are visible.
Remove the keyboard.
Remove the screws securing the monitor to the hinges, and
then set the monitor aside.
Disconnect all visible cables connected to the motherboard;
and then remove the screws from the top cover.
Remove the top cover to reveal the motherboard. Locate and
then remove the CMOS battery. Leave it out of the notebook for 24 hours; then
reinstall it and reassemble the Acer Aspire. Other Options
If removing the CMOS battery fails to clear the password, or
if you dont feel comfortable with the idea of opening your computer, you might
be able to gain access to the computer using a backdoor password.
These special passwords were implemented to allow
technicians to access locked computers. Not all models recognize backdoor
passwords.
Most Acer Aspires use the Phoenix BIOS, and backdoor
passwords for this BIOS include BIOS, CMOS,
phoenix and PHOENIX.
All of these passwords are case-sensitive.
Hi the only possible way to reset the password in the BIOS is to reset the CMOS battery. It is located in one of the panel below the sys (you must have proper expertise to do this) towards the right hand side. The battery is set on a jumper You first need to disconnect all power source i.e adaptor and battery. than remove the panels to try and locate the CMOS Battery. Remember not to tuch anything else or connect any of the cables any where else it may cause a problem for the sys and you. Once the CMOS battery is reset the BIOS password will have gone.
All the best
Here is the data that I have found:
In order to have the BIOS or hard disk password removed (This include any biometric security), the notebook will need to come in to our repair depot for password removal. This service is not covered by warranty and unfortunately there is no other recourse to remove a BIOS or HDD password from the notebook. The flat fee for BIOS password removal is $100.00 US dollars plus tax. If it is a BIOS or HDD password and you would like us to service it for you, please contact our telephone technical support line at 1-800-816-2237. Hours of operation are 7am-9pm CST Monday-Friday and 8am-5pm CST Saturday and Sunday, excluding holidays.
YOu can reset bios password with 2 method. (1) open back cover of
laptop then find motherbord .Pull cmos cell from motherbord for 15
minutes then again put it in it's position .then it not ask for
password. (2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3 Put jumper in 2-3 position then again put it in 1-2 position then check . Let me know if you need more assistance. Thanks.
Its very simple go to cmos setup when you start your laptop press F2 or Delete then go to security option when you find option for enable & disable password
REMOVE AND 20 MIN AFTER REFIX CMOS BATTERY. GO TO CMOS SETUP RESET DATE AND TIME...... IF NOT CLEAR VISIT YOU NEAREST MYTECH SOLUTIONS LAPTOP SERVICE CENTRE. WWW.MYTECHMADURAI.COM
if u froget your bios password then u have to open the back side of laptop.then find the cmos cell then pull away it for 15 minutes then refix again .then it reset then it dont need any passworde.
what might help ???? i can't understand.
forgotten bios password...and cant find a disassembly manual/video
I have a acer aspire one 532h-2588
