Question about Sony KV-27S45 27" TV
TV won't turn on, delay/timer light flashing
I have a sony kv-27S45 triniron tv. the timer delay light keeps flashing and it won't turn on. I've tried unplugging it and waiting for 60sec and holding down the timer button while pressing the power button....nothing. HELP!
Thanks
  • 3 more comments
  • penrodtlt Dec 04, 2008
    4 then a pause.
    Thanks
  • smithzoos Dec 24, 2008
    We have the exact same issue. Did the soldering help with this??
    Thanks,
    Regan
    smithzoos@comcast.net
  • Anonymous Jan 02, 2009
    No Picture no sound. Stand By Timer Light blinks 5 times on and off, then repeats. Sony Model #KV27TS27.
  • mrskbudd Mar 16, 2009
    We also have a Sony Trinitron 27 inch model number KV-27S45. T.V. comes on, but the picture just flickers, sound is okay. The Standby/Timer light is flashing 4 times and then the T.V. shuts itself off. We also tried to unplug it and waited, plugged it back in and it does the same thing. Help! We aren't comfortable with working on the "guts" of the T.V. and we really love this set!
    Confused and Sad!
  • Anonymous Mar 22, 2009
    same model (KV-27S45), same exact problem, 4 red blinks.
  • 4,234 Answers
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
Posted on Dec 02, 2008
  • ABRsvcs Dec 04, 2008
    The 4 blinks usually indicate the loss of vertical deflection. If you can solder and are comfortable wrking inside the set (realize that there are potentially dangerous high voltages present even when unplugged), you can fix this yourself.
    Look for a small flat IC attached to a heatsink that is marked TDA8172. That is the vertical IC. Try resoldering the pins first. If that fails to resolve the problem, replace the IC.
    Let me know the results as there may be other components in the circuit that need to be changed as well. If that is the case, the symptoms should change.
    Keep me posted,
    Dan
  • Johnny415 Jan 13, 2012
    I have same problem and my tv is a kb-35v68 it blinks twice on the timer then once on the stereo then clicks again and the process continues...need help please!
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
Mar 25, 2011 | Sony KV-27S45 27" TV
Tv wont turn on, red timer/delay light flashes starts to come on then shuts off again
hi,
watch how many times ur standby indicator flashes. flashing of led is its self diagnosing system. if u tell me how many times its flashes, then i can tell u where is the problem
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony kv-35s42 no picture, good sound timer light flashing
Usually, the CRT is bad......re-juvenation is a temporary fix at best........try adjusting screen control on CRT socket module.
Only other possibility is solder pins of vertical output IC.
Mar 20, 2008 | Sony KV-35S42 35" TV
Tv not working
u need to repair your tv from a technician. there is a problem in the internal circuit of your tv
Mar 09, 2008 | Sony KV-27S45 27" TV
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Clicks - but no picture!
According to the manual... Problem: 'a red light keeps flashing on the tv for more than a few seconds', What it could be: 'your tv may need service', What you can do: 'Call your local Sony Service center'
Nov 29, 2006 | Sony KV-27S45 27" TV
Sony KV-27S45 27" TV Logo
612 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
