Question about Mitsubishi CS-31505* TV
Shuts off by itself now wont turn off either by remote or power button
Has had this problem off and on for a several weeks. It turns off by itself, but I could turn it on and will stay on sometimes for a while or all day or evening. Sometimes, the process repeated a several times but I was always abel to watch. Now, it went off and I cannot et it to come back on by either remote or direct. It is 10 years old set.
5 Suggested Answers
  • 1153 Answers
SOURCE: tv powers on, then switches off immediately
check out and find error codes
Posted on Dec 25, 2007
  • 4234 Answers
SOURCE: When I attempt to turn on my 10-year old 60
There are a number of possibilitis for this symptom. Essentially, the set is shutting down because a problem has been detected in a circuit. Usually this happens and the fron LED will blink. Check for that as well. If it is blinking, it should be a pattern of blinks. Report that pattern here. With that info, we should be able to guide you through a repair.
Posted on Mar 09, 2009
  • 17 Answers
SOURCE: model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Posted on Jul 15, 2009
  • 63 Answers
SOURCE: Will not turn on. Shuts off immediately after turning on.
Sounds like the vetical deflection went out. Most likely have a leaking picture tube and the cooling fluid has goton on the board so you would be beter to replace if that is it.
Posted on Sep 03, 2009
  • 21 Answers
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Posted on Jan 20, 2010
0 characters
1 Points
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
My JVC 27" can not be turned on or off with the remote or the on an off button. Any ideas?
try all in one remote/it can be the infrared on tv not picking up signal/point remote does light flash on tv ?
Dec 23, 2009 | JVC AV-27530 27" TV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Tv just shuts off by itself
Don't use the power button on the t.v. itself to turn power on or off. Use the remote. The power button actually gets "stuck" and causes the t.v. to turn on and off, seemingly at its own accord. Make sure the button is all the way out and flush with the cabinet, then just use the remote to power on/off. Hope this helps.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
Shuts off by itself
Your unit may have a defective button, particularly on the power but loose contacts on the main component is the most that can cause the issue .
Have the main circuit be resoldered for loose contacts.
Feb 14, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Aug 26, 2007 | Sony KV-36XBR400 36" TV
If the set will not turn on with the power button on the front of the set, you must then try turning it on with the remote. You must be sure that the remote is working correctly. If the set turns on with the remote, then your power button itself is bad or has cracked loose. This is easily fixed without having to replace the board. If the set does not turn on with a working remote, then something inside the set has failed and it should be serviced by a qualified tech.
Aug 20, 2007 | Emerson EWF2704 TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Standard (CRT) Televisions Logo
21 people viewed this question
Top Mitsubishi Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Standard (CRT) Television Expert? Answer questions, earn points and help others
