Question about Kenmore 63942 Dryer
Dryer elec. works great no heat
Cant get any heat, electric dryer kenmore elite works great just no heat is there a reset switch?
  • 979 Answers
You either have a breaker tripped, a wire has burned off in the back, hi limit switch is bad(located under the hood) or last the element has burned in two.
Posted on Jan 20, 2009
Kenmore Elite 11063932102 is not working but no heat come out. What may be the problem?
is it coming on like it should but just is not heating if so it can b a number of things like a heat limit switch ,heat selector switch, heating element bad , a wire burnt off heating element or the switch on the motor (on some models)
Jan 24, 2011 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE4 Electric Dryer still runs but is not heating. The Manual says it could be 2 fuses or a circuit breaker but doesn't tell you where they are located. Where are the 2 fuses located?
it may be a reset switch on the motor, heating element or thermal fuse, here is a website that should help, Tim
Oct 24, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite dryer for about 4 years and it will not heat up. Can you please help?
check breakers in panel make sure both are in the on possition(home elec. panel)....if thats not it replace both heating elements...they are located on the back usually held in by 2 screws in each one..youll find these at lowes or home depot
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
