Question about Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 PC Notebook FN keys
Special function keys esc-F8 will not respond to the FN+ task... they will however work assigned regular function...(eg F5 will refresh page just fine) Toshiba Satellite 5005-S504 PC Notebook I have tried every thing I can imagine to do short of giving the lappy flying lessons out the door! Comment posted on Dec 02, 2008Ok thanks but I dont know how to even get into the bios to start... and second I can hit the fn + f11 and that turns on my 10key number pad so I assume the fn key is not disabled it is just the controls that go along with the fn key that I cant seem to get to work eg...esc= mute or f6 f7 brightness up and down or f1=lock, none of these work
Bios access key
Try F8, F2, F12, or delete key.
Dec 14, 2013 | Toshiba Satellite 5005-S504 Notebook
My toshiba satellite 5005-s504 wont start this happened when i instoles ie8 and want to restart after that it keeps on restarting what should i do
upon turning on the power hit f8 and then select safe mode with networking. once windows is up go to start>all programs>accessories>sytem tools and select system restore on system restore select a date before you installed IE8.Let it process and you should be good to go.
Apr 06, 2010 | Toshiba Satellite 5005-S504 Notebook
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Function keys dont work
Go BIOS and check if the FN key be disabled.
Nov 11, 2008 | Toshiba Satellite 5005-S504 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Solution
replace the keyboard
May 28, 2008 | Toshiba Satellite Pro M10 Notebook
Unable to get into BIOS SETUP
hi there,
On most systems, the key or key combination to press to enter the BIOS program is displayed on the screen when the system boots up, at the time when the BIOS is ready to enter Setup.
take a look at some default keys:-
  • {Delete} (modern Award and AMI BIOSes)
  • {F2} (modern Phoenix BIOSes)
  • {Ctrl}+{Alt}+{Esc}
  • {Ctrl}+{Esc}
  • {Alt}+{Esc}
  • {Ctrl}+{Alt}+{S}
  • {Insert}
  • {F1}
Apr 10, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
480 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
