Question about Continental Freezer Reach-In FreezersClick Here : Single Section Extra Wide Pass Through Freezer
I am getting [P1] code on my temperature indicator. It works find until this afternoon but suddenly [P1] shows up instead of number that indicate my temperature. What could be wrong or what do I need to do to fix it?
  • 237 Answers
Could you please re-post with the model number so I can look up the codes?
Posted on Feb 02, 2007
TEMPERATURE INDICATOR ON DOOR IS NOT WORKING
Truly... if it is an indicator that is not working you be buckets of money ahead to get a $7 freezer thermometer and work from there
but alas... I suspect you are encountering deeper issues.
Looking at "Appliance PARTS PROS"... Your model number (FUM21SVRWW) is not resolving to a good number (looks valid when I insert an A, B, C or D between the "V" and the "R").
Like FUM21SVARWW
With that I found A freezer part WR09X20946... definitely
(needs to be verified).
http://www.easyapplianceparts.com/PartInfo.aspx?inventory=11721885&SourceCode=1&SearchTerm=FUM21SVBRWW&ModelNum=FUM21SVBRWW
start at drawing part 43... drawing (top left corner)
Your model number (FUM21SVRWW) did give me a part... but it would not DOUBLE CHECK...
I think the sensor and controller are combined into a single control.
Always get three decent estimates... (SEARS PARTS = $$$$) shows your part as WR09X10063... but personally... I would talk to EVERYBODY else first.... I'm just saying...!!!
Appliance Parts was offering "try their part" return policy... which is wonderfully attractive to us amateurs.
Trust but verify.
Good luck and good hunting.
Jan 03, 2016 | GE FUM21SVRWW Upright Freezer
Why is my freezer on 0?
Good Afternoon Friend, this is Z. That's a great question!
Depending on the model number of your Frigidaire freezer, "0" could indicate two scenarios. First, if it is set to 0 (zero) that could be the temperature it is set at. On some models, "0" means that your freezer is in the off position. You can re-start your freezer by pressing and releasing the "UP" arrow 3 times. If it continues to display "0", press and release the "DOWN" arrow 3 times. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has change successfully. Thank you!
Jul 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer indicator
Good Afternoon Larry, thank you for allowing me to assist you!
I understand your freezer is showing "OFF". This typically means that the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try reactivating the freezer by pressing the UP arrow until the display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
I hope this proves to be helpful to you.
Jan 06, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Error code 8
Good Afternoon Glenda, thank you for your inquiry!
Is it possible that the error code is missing characters? According to my research 8 is not a valid error code. The number 8 is more like a temperature setting, however to be certain, let's try resetting the appliance. It is important to wait roughly ten minutes and then turn the unit on. Set the correct temperature and please allow 24 hours for the temperature to stabilize. The error code should clear and the unit resume to normal operations. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Best regards!
Sep 10, 2013 | Frigidaire Freezers
Of error code
Good Afternoon Jason, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Aug 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My true freezer temperature gage has a P1 flashing code
If unit keeps proper temp. then I would think that either the thermometer sensing probe may have been damaged during the repair process or the thermometer itself has failed.
May 13, 2010 | True Commercial Freezer TM74F
Have a look at the Make and model of your thermostat and download the Instructions from the internet or give ur local refrigeration mechanic a call and ask him they are easy to set
Mar 23, 2010 | True Commercial Freezer TM74F
Freezers Logo
795 people viewed this question
Top Continental Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Continental Freezer Expert? Answer questions, earn points and help others
