Question about Nintendo Wii Console
How do i program a wii controller - Nintendo Wii Console
  • mauree smith
    mauree smith Feb 01, 2009
    how do I hook up the second controller for guitar hero world tour for the wii console?
  • 3 Answers
Under battery cover on wii remote is a little red button. Under disc slot is a little flap where sd card goes in, next to this is a red square button. Press both red buttons at same time for 5 secs. Blue lights on wii remote will flash and everything will be fine.
Posted on Feb 02, 2009
Tip
How Control Your PC with a Wii Remote –
While some of us who jumped on the Wii bandwagon have a great time with Super Mario Galaxy and Cooking Mama, there are undoubtedly a few regretful gamers who just can’t get the hang of Nintendo's waggle-based gaming console. But there’s no need to chuck that Wii out the windows yet---you can use the Wii Remote as a wireless pointer for your PC!
   Find a compatible Bluetooth Adapter -
The Wii Remote uses Bluetooth to connect to the Wii, but Windows will also recognize it as a human Interlace Device. To connect the Wii Remote your PC, you’ll need a compatible Bluetooth receiver. Most new laptops have integrated Bluetooth, but you can also purchase a USB Bluetooth receiver online for less than $25.
Pair the Wii Remote with your PC -
I paired the Wii Remote with our Dell laptop using the "Add Bluetooth Device" option in the Windows control Panel. For the laptop to recognize the controller, I also had to press the red sync button in the Wii Remote’s battery compartment. Your PC should detect it as Nintendo RVL-CNT-01. No Bluetooth passkey should be required.
Run WiinRemote software –
Now, download and launch the latest version of WiinRemote  (Download  it from http://onakasuita.org/wii/index-e.html). If you successfully paired your Wii Remote, the program will let you calibrate the motion sensor and assign buttons. By default, The program user site controller's gyroscope to control your mouse cursor. The Wii Nunchuck peripheral’s analog stick will also control mouse movement. Yon can achieve more accurate control by activating their sensor, bus you’ll need to mount two infrared light sources above your monitor for this to work. The Wii's IR light bar is suitable, and I powered it by splicing its proprietary plug into a USB cable.
So sit back and enjoy the comfort of using a PC with a remote......
on Dec 09, 2009 | Computers & Internet
How do you program the wii remote for 2 players
take the battery cover off the wii controller and press the red button. then open the cover at the front of the wii and press the red button. do this when you are at the wii menu. this registeres the remote
May 29, 2010 | Nintendo Deca Sports for Wii
How do i program another control to my sonsole
The Wiimotes have a small red button next to the batteries, and the Wii itself has a red button under the SD card panel; press these simultaneously while your Wii is powered on, and then press A on your Wiimote. That should do it.
Mar 26, 2010 | Nintendo Wii Console
Setting up my Wii system using Harmony 670 Remote
I just thought you should know the Harmony Remote is only able to control any device that uses infrared control. Unfortunately the Wii console uses Bluetooth technology which means the Harmony Remote would not be able to control it.
Hope this helps you!
-Kennedy
Feb 23, 2010 | Logitech Harmony 670 LCD Remote Control
I have a logitech remote for my tv, just bought a wii game. Do i need to program it into my remote as i cannot get the wii to work?
Because the Wii does not have IR receivers, it is not directly compatible with the Harmony remotes. However, you can still create a "Play Wii" activity that will turn on your other devices that are needed for the activity and set them to the correct inputs. So, for example, you would still need to turn the Wii on manually, but you the "Play Wii" activity would turn the TV on, set the correct input for the Wii and activate your sound system (if separate from the TV). Hope this helps!
Feb 17, 2010 | Logitech Harmony 880 LCD Remote Control
My second Wii controller does not connect. It used to work, but now no matter which reset I use (on the controller or on the console next to the SD card), nothing works. I have placed new batteries in the...
Have you tried one time syncing it? (By pressing home and then pressing reconnect controllers)
If you have make sure you're not trying to connect it in a single player game. If you do, the second controller will not connect.
Jul 27, 2009 | Nintendo Wii Remote Controller
How do I program my Wii controller for my Wii?
Underneath the battery cover on the Wiimote there is a small red or black button, on the Wii console by the SD card slot there is a red button. Press theb utton on the Wii console and then the button on the controller and that will sync that controller to the Wii console.
Feb 19, 2009 | Nintendo Wii Console
Wii controllers
Sounds like the remotes aren't sync'd up with the Wii in a way to turn it on. I had a strange occurrence with ours where only 1 Wiimote (ha!) out of 4 would turn on the Wii with the power button. Try following the instructions to program the Wii to the Wiimotes again and see if that works. Also try holding the power button on the remotes a little bit longer.
I don't recall but you push the red button behind a hidden cover on the front of the Wii and then the button on the Wii controller behind the battery cover.
Dec 31, 2007 | Nintendo Wii Console
Need help programming wii console remote
take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
Dec 19, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
64 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
