Question about Mamiya 645AF Medium Format Camera
Mamiya 645 af focus problem
Every so often when getting the developed film back the centre of the photo is slightly out of focus. It seems to be a random occurance as the shots either side are usually perfect. This is useing the 80mm af lens. Is this a lens problem or camera one? Anyone had similar problems?
Thanks Andy
  • Andy Hughes
    Andy Hughes Dec 03, 2008
    Thanks Spotatohead
    The lens is ok. It seems to be a problem with the film not laying flat behind the lens. It seems to appear when the camera hasn't be used for an hour or so and on the frame that winds on after the shot has been taken. Is this a comon problem with the Mamiya AF camera.
    Cheers Andt
  • Timm Chapman
    Timm Chapman May 11, 2010
    Look at the rear glass of the 80mm lens? Any marks/fingerprints in the centre? If so, that might be causing it. Marks become more pronounced on film when the mark is on the rear glass closer to the film plane.
Mamiya 645- broken mirror stop.
If you find a source, do share. I am looking for the shutter stop to be fixed on my Mamiya 645 Pro TL as well. I saw someone online made one out of metal himself... seems like the way to go, but lot of effort.
Jan 12, 2014 | Mamiya 645 Pro TL Medium Format Camera
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to...
if the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
thanks.
Oct 11, 2008 | Mamiya Cameras
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
I just purchased a used back roll film holder for my Mamiya 654 Pro TL, and I cannot pull the dark slide out. This dark slide has a blue handle, where my other back's dark slide has a red handle, and...
It's been a while since I used a mamilla 645, so forgive me if this is wrong, but I seem to remember the dark slide would only come out with the camera wound on, ready to take a picture.
Dec 26, 2017 | Mamiya 645 Pro TL Medium Format Camera
Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Jan 09, 2011 | Mamiya 645 Pro TL Medium Format Camera
Mamiya 645 AF back won't advance film.
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Feb 07, 2010 | Mamiya 645AF Medium Format Camera
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Jun 15, 2009 | Mamiya 645 Pro 80mm F2.8 N/L Lens
Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Jan 07, 2009 | Mamiya 645 Medium Format Camera
Shutter stays open on mamiya 645 M
Get any crud from the battery out of the works with pH-neutral stuff and q-tips or lint-free towels, and see if it works (without film; might as well check current drain with a bench supply instead of a battery, too) once you've done a satisfactory job of that.  Then visit a shop so they can see if the shutter timing is tolerable...and perhaps sometime you can load film in again.
Jul 31, 2008 | Mamiya 645 Medium Format Camera
Mamiya 645AF Medium Format Camera Logo
149 people viewed this question
Top Mamiya Photography Experts
Tony
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
