Question about NorStar T7316E Corded Phone
Caller ID not work on Nortel T7316- IS there a code to activate
Hello, is there a code to activate the caller ID on a T7316 Nortel Phone
  • 2 more comments
  • cindy21 Dec 08, 2008
    I have added caller id service to my system but the phone just says transfer when I pick up the call.
    The company that installed our system is no longer in business so I do not know where to get help.
  • cedo131 Jan 21, 2009
    I have the same problem. What good is caller id after you pickup?
  • phtechoftx May 11, 2010
    Is the system equipped with a CI (caller id) line card? System programming settings to check...Are lines programmed to ring on the phone? Is the phone ext. set as CID set?
  • Carl Navarro
    Carl Navarro May 11, 2010
    CID requires CID service from the phone company and CID trunks on your phone system. IIRC it's automatic if you have the proper hardware and it will, at least, be displayed after you answer the call. Check with your phone system supplier to see if you have the right system.
zowl
  • 15 Answers
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
Posted on Mar 12, 2008
ynotphone
  • 192 Answers
SOURCE: Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Posted on Jul 16, 2009
SOURCE: nortel norstar m7310 phone caller id problems
did you change extension numbers? Or did your extension number move with you?
Posted on May 08, 2008
SOURCE: how to set time & date on phone
If you subscribe to Caller Display services, the first incoming call will set your phone's date and time automatically. Otherwise, here is how you do it.
1. press Options 2. Press * three times The display shows "Enter time/date?"
You may set both time and date or you may set either of them separately
TO SET BOTH 1. Press # when the display shows "*=Next #=Enter" 2. Wait for each prompt. You will be asked to enter: - the time - am or pm - SAVE - the month - the day, and  - SAVE (Enter the hour, day, and month as two-digit numbers. For example, enter 02:15 for 2:15, 05 for May and 08 for the 8th of the month.)
TO SET ONLY THE DATE 1. Press # when the display shows "*=Next #=Enter" 2. Press * when the time appears 3. Enter the month and day when prompted. 4. Press SAVE
I have a question for you: Can you give me the specs of the AC adapter for this phone (usually written on the adapter)? 1. What is the OUTPUT in volts (V)? 2. What is the OUTPUT in milliamperes (mA)?
3. What is the polarity (i.e. is the + sign in the center of the jack or on the exterior)?
(The wall plug transformer has a diagram depicting two circles with the inner circle representing the center conductor. A line coming from the inner circle will show a minus (-) or a plus(+) symbol to let you know the polarity of the center conductor.)
Thanks!
Posted on Dec 01, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
Posted on Dec 05, 2008
Caller ID is not working
Hello Samiran mandal, here is a solution.I purchased one cordless telephone (Siemens Gigaset) in Germany. I also had the same problem, caller-id did not work. I purchased this telephone because we can set different ringtones for different caller groups. But, if caller-id doesn't work, this feature also doesn't work. I had gone through internet and finally found that CA electronics, Bangalore has it and got it through courier (I live in Pondicherry). It worked flawlessly for two years. Then it stopped working. For 'no reason' I ordered for a 'caller-id' unit on ebay for Rs.75/- (+ Rs.75 shipping). I just got the unit and fixed it to my line. Very very surprisingly, my cordless telephone is now showing caller info. This is a real surprise to me. By the way, caller-id unit is "Eurotel" make, DTMF/FSK caller-id. I feel this is very nice solution. The 'caller-id' unit is nice (backlit display) and also there is no need of converter for using the caller-id feature of your foreign telephone. I connected caller-id between the line and telephone. That's all. Enjoy.
Apr 12, 2013 | Lands Phones
My t7316 is no longer ringing at my desk or showing the caller id
You can set the ringer volume by using Feature *80 and use the volume control to change the level. If this does not get your phone to ring again, then the line assignments will need to be reprogrammed.
Mar 19, 2013 | NorStar T7316 Corded Phone
How do i change the outbound caller id number on the T7316? several of our users lines are currently programmed with my number as their outgoing caller id number, so their clients keep calling me back...
I found this guide that has a lot of information regarding the programming of the Norstar phones..
Hope this helps you!
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Mar 31, 2011 | NorStar T7316E Corded Phone
Our caller ID has stopped working and this has nothing to do with our monthly ATnT service
The caller ID facility is an optional facility provided by your Operator and this needs to be activated from operator side in order to show in customer's Called ID device.
Please check it with any other line that has the same facility activated.
Jan 21, 2010 | Nortel Business Series Terminal T7208 -...
Caller ID not working on my t7316 phone
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Sep 16, 2009 | NorStar T7316E Corded Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
Caller ID
First off seven to nine you do not use an external cid unit for norstar systems. Make sure you have a caller id card in the main ksu or key service unit( the phone cabinet) It should say CI on it. If the card says DS then you do not have a caller id card on the system and will need to exchange it for one. Then the system phones will have to be programmed for cid.
Feb 16, 2008 | NorStar Meridian M7310 Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Oct 25, 2007 | Lands Phones
NorStar T7316E Corded Phone Logo
3,984 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
