Question about Refrigerators
Fridge not cooling contents
My fridge is 2 years old and its normal fridge motor/compressor noise is heard every 1 minute for about 5 seconds. Consequently not cooling at all.
  • vannafrangos Dec 03, 2008
    How do I replace the overload? Is it a DIY job?
  • 121 Answers
The relay on the compresser is trying to start the compresser so the relay or compresser is bad
Posted on Dec 02, 2008
    Scholar:
  • 62 Answers
YOU DIDN'T STATE WHAT MAKE YOUR UNIT IS, HOWEVER IT SOUNDS LIKE IT IS THE OVERLOAD COMPONET THAT MOUNTS ON THE COMPRERSSOR TO START IT. TRY THAT FIRST IT IS THE MOST COMMON.
My Fridge isn't cold anymore, what could be the issue?
call a repairman , sounds like it need freon added
Nov 17, 2015 | Refrigerators
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Buzzing noise every 5 to 10 minutes, like an ice machine turning
No ,very possible it is due to expansion. There is a covering on the return pipe called armour flex. this armourflex stops ice migration inside the walls of the fridge. If it breaks away, the ice expands around the pipe and and pushes on the insulation foam which then cracks and makes those loud noises. Have heard this noise many times on a particular brand of fridge to a point where some customers have dived for the floor thinking they are being shot at. Repairing that problem is a biggish repair and not cheap. You will find if it is the compressor it normally only happens at either start up or switch off (a clattering sound)
Sep 19, 2009 | Kenmore 64802 Top Freezer Refrigerator
After moving fridge (and waiting 36 hours) compressor won't start
You should worry , the 12 amps is a locked rotor on the compressor , it may be the over load relay control on the compressor as well , try replacing the over load start relay first , they are not expensive , if this does not fix it you can try installing a booster like a rco410 but the comp. can not take that abuse for years from the booster. when the comp. is running normal it will draw roughly 1.5 - 3.0 amps.
Phil
Apr 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Refrigerator
You didn't mention it, but I'll bet there's a "humm" followed by a "click" noise coming from the back of the fridge. Even if you don't hear the noise, the starter on the compressor has failed. One of two things cause this... 1.) A mechanically failed starter. 2.) A seized compressor. If it's the starter only, you are in good shape. If it's #2 and the unit is less than 5 years old, it'll be a warranty claim. If the unit is less than 5 years old... do not attempt the repair yourself. Because, if you do and find the compressor locked up, you have voided your warranty and they will not repair for free. If it's over 5? Install a starter. We need the FULL model number off of your fridge to provide steps on this. It's located on a data tag affixed to the inner fresh food section lining. Most likely near the top on the right. Please post back with these numbers if you require further assistance.
Aug 11, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
