Question about Microwave Ovens
KCMS185JSS-1 Microwave test results
Thank you for your prompt suggestions yesterday.
I checked the stirrer motor and that runs freely.
I ran the water test. After 63 sec. the water only increased 5 degrees F. So I guess the magnatron is only pumping out ~ 350W.
What next?
Regards,
Phil Marcoux
Mountain View CA
  • Microwave Ovens Master
  • 9,030 Answers
Assuming your power line voltage is right, bearing the whole thread in mind, I'm sure you have a bad magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you follow the safety & disassembly info, this is not a difficult job for a do-it-yourselfer.
Posted on Dec 05, 2008
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Oct 15, 2012 | Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
Oct 10, 2012 | GE Microwave Ovens
On my amana rfs8b the stirrer or bracket cought on fire , whould the stirrer being stuck cause this?
Yes! it is more than likely that what happened [ motor overheated because it was seized] my main concern is the magnetron, if it ran for all that time without food, it has more than likely sustained damage.
May 22, 2012 | Amana Microwave Ovens
It catches on fire, through the center turn table.
NOTHING in a microwave should ever be on fire. Depending on the damged cause by even a small fire, the repair may be involved and costly. Inspect stirrer motor by removing bottom of microwave with power off. Note damage and replace stirrer motor and wiring harness as needed along with turn table drive block. Check to make sure all connections with all wires are sound with no exposed copper wires or shorts of any kind. Test always using a cup or bowl of water.
Jul 02, 2009 | Microwave Ovens
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
Jun 15, 2009 | KitchenAid Microwave Ovens
Turntable in GE microwave stopped turning.
On some GE models, the turntable motor and stirrer motor are powered off a tap on the internal cooling fan motor and in such cases they will be marked "21V AC".
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
A quick test is to remove the stirrer cover in the ceiling of the oven. The owner's manual tells you how, and you can download that here.
Then run the oven for several seconds with a cup of water inside while watching the stirrer blade in the top. It should turn very slowly.
If it does not turn or is jerky, it or the cooling fan is not working.
Also, we have a sound clip of what a microwave should sound like when the cooling fan and everything else is working here. The cooling fan's absence will be notable after you hear the clip.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If the cooling fan is good, but yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from thew wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
1800XL microwave hums
A test bench will have known-good power, but disconnectable and on a breaker and metered, for example.  The lamp will be disconnected by opening the thing up (hence, the workbench setting) and removing the lamp circuit connections in whatever way is most convenient.
The stirrer is often integrated with the output from the magnetron to the oven cavity; it's a microwave component that literally spins as the thing runs, and since the oven light is commonly on the same side easy to see moving or evidenced by changes in the back reflections from its vicinity.  That is, you would notice some periodic change in the internal oven illumination from the stirrer's motion, which might have stopped around the same time the hum started....
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ticking sound when running microwave
It may be a noise coming from the turntable motor or stirrer motor, if so equipped.
If it's not too loud, I wouldn't worry about it unless it gets louder or you get further symptoms.
Nov 19, 2007 | Kenmore 62622 Microwave Oven
Microwave issue
It could be a bad motor. You really need to connect it to power to fully test it. It may also be that the stirrer is binding.
Oct 23, 2007 | Microwave Ovens
Microwave Ovens Logo
109 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
