Question about Acer Aspire 5315 Notebook
My wireless button on my laptop dont show up and wont work
My wireless button wont turn on
hi,
1, check and replaced button
2,re install device driver
Aug 28, 2014 | Acer TRAVELMATE 2451WLMI COMPATIBLE LAPTOP...
Hi all! My laptop model is dv7. The problem that i meet is Wireless button and lighting button doesn't work. Any help to solve this problem? And how to use remote control?
hi if the wireless button is not indicating in blue light and still you get the internet . then the problem is with button. still your getting internet i dont thnk its a serious problem, the LED inside the button has got fused. or Just restart your computer sometimes the button will again show blue light get worked . dont open the laptop inner parts just go to near service centre
Jan 11, 2011 | HP Pavilion dv4000 Notebook
Wireless button showing amber, but wont change when pressed
WIRELESS NETWORK BUTTON FIX FROM RED TO BLUE. 1. Press wireless button. 2. left click the dialog box in the bottom right corner it will prob say wireless disabled etc. 3. HP wireless assist box should open if so its working and you should click on properties. 4. check all unchecked boxes and press apply or ok etc.5 you should now see in the top right corner of the HP wireless assist box an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Apr 15, 2010 | Compaq Presario CQ60-220US PC Laptop
Cant locate wireless networks
there should be a button that will turn on your wifi on yer computer. but most of the time, you just wont be in any range of any wireless networks and if u are, and still dont see em, then the router is probably turned off or not working.
Dec 27, 2009 | Advent Netbook
Reinstalled windows onto acer travelmate 2410 and downloaded all drivers etc but when going into device manager there is no wireless card showing. how can i get the wireless to work now?
There will be a button to start up or power on the wireless device. so switch it on then it will start detecting the wireless hardware for driver installation.
Please dont forget to Rate my answer
Sep 05, 2009 | Acer TravelMate 2300 Notebook
I have a balance 557s laptop that the wireless wont work it shows the icon with a red x wont turn on when you push the wireless button
Sometimes when you get a red x against the wireless icon, it means the wireless card did not get an IP address from the wireless router or the router needs resetting.
To get the router to issue a new IP address to the laptop, right click on the wireless icon and click on Repair.
If this doesn't work, power off thr router for 30 secs and power up the router, wait till the LEDs on the router are on then boot up the laptop or do a Repair on the wireless icon.
Aug 27, 2009 | Computers & Internet
I have a acer travelmate 3000 laptop and cant get my wireless to work, if i plug in a new wirless usb stick it works fine but i wont the internal wireless to work, does this mean my internal wireless card...
Odds are pretty good the wireless is not enabled.
If you look at page three item three of the manual, it shows the button/indicator on the front of the system to enable wireless.
http://www.acerpanam.com/synapse/data/7117/documents/TM3000_UG_Eng.pdf
Jul 17, 2008 | Computers & Internet
Wireless wont work wont come up
Do you mean it won't show up at the bottom when connected or it won't show up at all (so you can't connect)
if it's not there at all, then its probably switched off, look for a switch or a button on your laptop (if it is a laptop) to turn it on.
If its not a laptop then make sure your dongle is installed properly.
If its none of these then can you be a little more specific with your question please
Mar 04, 2008 | Computers & Internet
My laptop cant find the card
is your card connected proper if so l would say its faulty now
Mar 03, 2008 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Acer Aspire 5315 Notebook Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
