Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Oven won't pre-heat
all of a sudden none of the touch buttons will work (except for the off button, which only beeps and the self clean button). When I open the door, the light goes on and the clock is working but the oven won't let me cook. What's the deal?
    Sergeant:
    Champion:
  • 338 Answers
You have either a bad touch panel or a bad control board. try reseating the ribbon cables on the control before replacing. just remember to turn the power off before opening the unit
Posted on Dec 07, 2008
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I used the Self Clean function on the oven and now the oven will not pre-heat or heat at all. All that happens once the clean is complete is that the clean light blinks. I have cycled the self clean...
unfortunately the reset button is usually inside the controls compartment, the upper back piece has to be opened and push the red reset button inside.Hpefully this helps and dont forget to unplug first for a couple minutes to attempt erasing fault
Jan 20, 2011 | Ovens
Worked fine all of a sudden it is flashing and beeping F-7 ??? wont heat up
F7 Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock. So first try checking the touch pad buttons.If any of the button got internally stuck then its the cause of error.Release the button and see if that helps.But if all button looks ok then its faulty touch pad causing this error.It has to be replaced. ----------------- You can get required part from www.repairclinic.com ------------- Thanks.Helpmech.
Jan 07, 2011 | Magic Chef Ovens
My electric range sens-a-clean button will turn on and then start? comes up and i hit start. then E1 F5 comes up. the door will not lock nor will it start cleaning. none of the other buttons will work...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | Kenmore Kitchen Ranges
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning keeps popping up beeping with F5
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Jun 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Ran the self cleaning cycle on my Kithen Aid electric range and once the cycle finished the touch pad would not unlock, the oven door unlocked but none of the touch pad will work except for the the button...
This is a common problem with all self cleanig ranges. The 1200+ degree heat will sometimes leak up into the control panel and damage components. Try turning the power off first for 30 minutes and see if the control resets itself. If it doesn't have directions on the panel, then check you owners manual to see if their is a certain procedure you use to unlock your contols. If none of these work you will need to have a technician come out to diagnose your elecronic range contol or you touch pad. Good Luck Appliance Specialists
Dec 14, 2009 | Food Processors
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Kitchen Ranges Logo
111 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
