Question about Dryers
My dryer gets really hot, but the clothes take a long time to dry and it is really humid inside the dryer. Also, there is a weird smell almost like a burning smell.
  • 75 Answers
It sounds like the dryer isn't getting enough airflow, which might mean a clog.
Make sure you clean the lint filter every time. Also, make sure the vent hose isn't kinked or clogged (if you can, remove the vent hose and clean it out.) Also check between where the vent hose connects to a wall or pipe. There could be a lint clog anywhere between the dryer and where the air leaves the house.
Posted on Dec 02, 2008
My Maytag Bravos XL electric dryer doesn't dry clothes. When I try to run a second cycle it seems like it's too hot and won't start again until it cools.
Make sure your vent pipe is clean and filter is clean. Air flow is number one reason for dryer failure, Check the whole inside of the dryer for lint build up and in the exhaust pipe. The dryer has to vent the humid air in order to dry the clothing. If it can't do that, it overheats and also the humidity stays inside the dryer.
Oct 27, 2013 | Maytag Dryers
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
My daughter left clothes in the dryer and they werent dry now my dryer smells soured. how do i get rid of the smell?
Try tossing a tad of dry baking soda in with the clothes in may take a time or two but it would be better than tossing the dryer. If it smells like mildew also maybe try placing some charcoal inside withe door shut, charcoal draws mildew.
Nov 06, 2009 | Estate TEDX640JQ Electric Dryer
My dryer has heat on the inside of it but it is not drying my clothes. i have to run the dry cycle three times.
You need to make sure your exhaust is not kinked or clogged up any. If the dryer does not have good air flow, it will not dry good.
Best way to check this is to remove the exhaust line from the back and dry some cloths with it off.
Sep 05, 2009 | Dryers
Kenmore dryer gets really hot on top of the dryer, not while clothes are drying but when finished, kinda scary?
Remember heat rises. However if it burns your hand or you can smell something you need to unplug the power to it asap. Most of them come with a one year in home service repair. It takes a while the heating elements to get hot in the dryer so that's probably why it seems its getting hot on top after the clothes have been in for a while.
Sep 03, 2009 | Dryers
Sears Kenmore gas front loading dryer doesn't get very hot (need to run 2x to get clothes dry), room is very humid and hot while running dryer
check the following areas to address this issue further.
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jun 21, 2009 | Kenmore 75944 Gas Dryer
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
125 people viewed this question
Top Dryers Experts
