Question about Maytag MGR5750 Gas Kitchen Range
Too hot temprature is incorrect
When i set my dial at 350 after i allow preheat time the oven temp was 450 and climbing. it burns every thing i cook. if i don't watch out. Can I readjust the thermostat somewhere?
    Habit-Forming:
  • 171 Answers
Yes, in the senter of the shaft of the oven knob.
Posted on Dec 06, 2008
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not preheat
You have burned out element(s). Lowering the wattage, therefore increasing the time it takes to reach set temp,
Apr 05, 2010 | GE JBP66 Electric Kitchen Range
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. Catriver...post back
Nov 01, 2006 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
Maytag MGR5750 Gas Kitchen Range Logo
145 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
