My Carrier 58dxc is making a loud noise
My carrier 58dxc is making a loud knocking noise and blowing out cold air. When I switch the thermostat to air the knocking stops and the unit works fine. It's only when I switch it to heat is when the knocking noise starts and the cold air comes out. Can anyone help.
  • 85 Answers
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Posted on Dec 03, 2008
I have a carrier furnace and it seems to be only blowing out lukewarm or cold air and my house only gets up to 63 degrees
Make sure your filter is clean and that your heat registers are open and the cold air return is not blocked. So if you turn your thermostat up to 70 degrees is the burner shutting off before the house gets up to temp? If the thermostat has batteries are they new? Out side of that you may need a service tech.
Jan 01, 2018 | Carrier Heating & Cooling
My carrier hotel style heat/ac unit just blows cold in electric heat or heat pump setting
check the thermostat also check the inline fuse for the electric heat coil . check wires in control panel they tend to burn and last check to make sure reversing valve is changing over located by the compressor
Mar 05, 2015 | Carrier Heating & Cooling
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
There a loud noise coming from the bottom of my unit
Hi There,
Check the fan drive belt & motor. Hope this helps and thanks for using FixYa!
Mar 30, 2009 | Carrier 38CKC036 Air Conditioner
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
FURNACE MAKING LOUD NOISES
My weathermaker started making a screeching noise and intermittantly would shut down, without blowing any heat. I found the sediment trap clogged and the induction motor was churning through the backed up condensation water. This slowed the motor down and the pressure switch would not stay closed. Unclogging the trap and hoses solved the problem. A bunch of water came out when I disconnected the collector box drain hose, along with gobs of sticky crud. Works great and is quiet now.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
338 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
