Question about Sewing Machines
My sewing machine keeps coming unthreaded. How can I fix that problem?
  • Lee Montoya Dec 03, 2008
    I tried everything. I guess that machine is messed up fer good. I'm just gonna throw it away
  • Lee Montoya Dec 08, 2008
    I'm gonna eep trying the tension
I would check your tension, play around with it till it stops, otherwise not sure
Posted on Dec 03, 2008
Why does my needle keep coming unthreaded? It sews 2-5 stitches then my needle cones unthreaded.
check that your needle is in the right way ie. with the flat face facing away from you. Is you tension correct? that is doe the sewing look okay?
Oct 30, 2014 | Simplicity Sewing Machines
My needle keeps coming unthreaded when sewing
normally when you use longer thread tails of 4 to 6 inches and move
the thread tails behind the needle before starting to sew.
Mar 07, 2013 | Singer 7436 - INGENUITY
My needle thread doesn't break, but when I go to sew, it unthreads itself.
make sure to keep long thread tail for the top & bobbin
of 4 to 6 inches & pulled behind the needle
Aug 04, 2012 | Kenmore 15516 Mechanical Sewing Machine
Sewing machine super lock
check the tension first
make sure the needles is not damaged
make sure the thread tails are long enough to pull behind the needle
toward the back of the machine
make sure the machine is threaded correctly
I suggest taking the machine to a sewing machine shop to have the
machine checked to see if the machine is out of time, the sewing machine technican can tell you for sure.
Jul 30, 2012 | White Sewing Superlock 2000 ATS Mechanical...
After automatic thread cut the needle comes unthreaded
you need long thread tails, of 3 to 6 inches for the top & bobbin thread so the needle doesn't come unthreaded,
also pull the thread behind the needle before you start to sew
Mar 27, 2012 | Brother PQ1500S Computerized Sewing...
It keep coming unthreaded at the need when i start sewing
You must hold the top thread at the start of every row of stitching, if you dont then the tension will pull the thread backwards.
May 16, 2010 | Sewing Machines
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Most machines need to have the thread extend to the back of the machine in order not to come unthreaded.
May 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
My thread often becomes unthreaded from the part that raises and lowers the needle causing the thread and fabric to jam up
Your needle should not come unthreaded in the middle of sewing.. if it does, it is because the thread breaks. this can be a simple tension problem or brittle thread.
if you are talking about at the beginning of sewing that the needle comes unthreaded, then you should just pull out 6-8 inches of thread through the needle before putting your fabric under and begin sewing.
i hop that helps.
Apr 16, 2008 | Singer Featherweight 132Q Mechanical...
Kenmore Sewing Machine 385
check the Bed Drop Lever
Im having the same problem but the lever is not enguaging the bed
Feb 10, 2008 | Kenmore 16622 Mechanical Sewing Machine
MACHINE COMES UNTHREADED
your bobin case needs to be tighten there is a screw on the case turn the screw to tighten .good luck.
May 06, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
