Question about Kenmore 24032\24036 Top Load Washer
How my i find the mechanical diagram for washer Kenmore-400?
The agitator shaft has a big free play, I sthinhk that some bearing or bushing is worn., and I'd like to get the mechanical diagram from this washer ( Kenmore-400)
    Sergeant:
    Champion:
  • 291 Answers
Take the 2 screws out from the front of each side of console pull forward and swing up ,,, it should be inside there / larry
Posted on Dec 02, 2008
Kenmore elite mod# 11024942300 unit # 0009538 machine will fill w/water drain and spin. Makes noise when washing cycle the thing in the middle will not rotate/move like it should. makes noise like ball...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://beta.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24942300&pathTaken=partSearch&prst=0&shdMod=110.24942300
and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft. Also check that the Agitator Dogs aren't worn / damaged.
Following is a description of how to take the agitators out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
In answer to your other questions:
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Jul 31, 2010 | Kenmore Elite 21086
I have a kenmore 70 series washer and the agitatior just spins freely when off is this normal
This assumes that you have a basic Kenmore2_bing.gif / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Following is a description of how to take them out.
I'd also check the Motor Coupler for a worn center rubber piece.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=bcf6e5e944400b9ef62cc7cb892700af
Jan 17, 2010 | Kenmore Washing Machines
Washer now agitating lazily. Ken. HD 60 series. Agitator doesnt seem to be fully connected? How do you remove the agitator?
Jan 16, 2010 | Kenmore Washing Machines
Washer agitator does not work (turns free)
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
Nov 25, 2009 | Kenmore 24932 Top Load Washer
Agitator does not turn ..... you can hold on to & it doesn't turn in wash cycle
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
If you move the timer to the spin cycle and the washer drains and spins, the motor coupler (A common replacement part) is OK.
This points to one of two possible solutions.
First, I'd remove the agitator(s) and look inside at the splines inside the agitators and at the splines on the main agitator shaft.
Here is a description of how to remove the agitators. Your washer may be a bit different but the Sears site should help to determine how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7a980a8b05b84ff3b7ee1c8ba46e2ae8
If yoy have a two piece agitator and only the top section doesn't agitate, the problem is likely the agitator "dogs" as described in the illustrations.
If the Agitator splines are worn or damaged, You'll have to replace the agitator.
If the splines on the transmission agitator shaft are worn, you'll probably need a new or rebuilt transmission.
In addition, see the following Whirlpool / Kenmore service manual and parts list for their commercial washers (consumer models are basically the same).
Oct 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 70 top load barely agitates....
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Older kenmore washer doesn't agtat the frist load but works fine the rest of the day (has new belt) moter works fine
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
From Repairclinic
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not agitage the clothing. The clothing rotates in one direction within the washer tub.
Hold the inner tub and turn it bothways. if it is free in both directions you have a bad bearing. If it turns in one direction only, the bearing is good.
Your agitator has a series of interlocking teeth on the inside which lock onto the corresponding teeth of the motor shaft. If these plastic agitator teeth are worn it wont grip the drive shaft, hence, no agitation.
Jul 23, 2008 | Maytag Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
875 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
