posted by RPM Guy on Feb 01, 2007
Mouse has been in use since 06-01-06.
The left click button will at times not respond.
The batteries are good.
Tapping the moouse flat on a table surface makes it work
for 5 or 6 more clicks.
It seems that the contact points inside the unit are needing cleaned.
How does this particular unit disassemble for cleaning?
Solution #1
posted on Feb 01, 2007
Hi RPM GUY,
I have a couple of these too but what you?re describing is just the button wearing out from lots of use. Since it?s less than one year old it probably still under warranty, taking it apart would definitely void it. I would contact Microsoft hardware support and try for a warranty replacement.
If you want to go ahead anyway remove the 2x batteries and you will see a screw inbetween. Remove it and the bottom half will come appart.
Let us know if you have any other questions and please don?t forget to rate the post.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Microsoft Wireless Optical Mouse
Email this problem
Email this problem
Can you Help with these Keyboards and Mice problems?
Repair Service
Find Keyboard and Mice Repairman Near You:
