Question about HP Officejet 5610 All-In-One InkJet Printer
I can't intsall HP Officejet J4500 software into computer.
I keep getting a fatal error message. It also includes an error code number which is 1335 and 2902.
I had the same problem. It was because I had Windows 2003 and needed the 2003 drivers. The CD had drivers for XP, Vista and Windows 2000. Not sure what OS you have, but all you need to do is find the drivers that are compatible for your OS online. Only takes a few minutes to install. After that you should be fine.
Posted on Dec 29, 2008
It must be a os problem, u have to reinstal the os again.
Posted on Dec 04, 2008
I purchased the HP officejet 4500 all in one. The message "fatal error" comes up while installing. I have business Vista. What do I do? Thanks. Lisa
some errors usually include a four-digit numbered code. if there is, please let me know. I also need to know the exact error message. where do you see the error message? on the computer or printer? PLEASE TAKE NOTE THE EXACT ERROR MESSAGE AND LET ME KNOW.
for the mean time, you can use the printer without troubleshooting the error by just installing the basic driver. the product will still print as usual however the product might not have its full functionality. steps in installing the basic driver: restart the HP software installation then select the "express" or "minimal" installation option instead of the "full recommended" installation option. Then follow the on-screen instruction to complete the installation.
Jul 26, 2011 | Office Equipment & Supplies
The printer is showing a message catridge error - Refer to device documentation to troubleshoot.
This is an internal electrical malfunction within the cartridge - I suggest you run the following two service tests:
1) You can 'temporarily' bypass an 'Incompatible Cartridge' error (or any other cartridge electrical malfunction error for that matter) by accessing the OJ's service menu...see the Inkjet411.com support youtube video found here:
HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
2) You can also run the 'tap 41' diagnostics check on the HP 901 cartridge(s) electrical health, via the access code/procedure shown in the following video:
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
Jan 17, 2011 | HP Officejet 4355 All-In-One InkJet...
New black cartridge wont print
Hi
check expire date on cartridge
perhaps you need to replace it
or clean it from maintenence menu
of your printer
In case I had help you pls vote me
Nov 06, 2010 | HP J4680 Office Jet All-In-One Printer
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge Error: Cart. on left is not intended for this printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab64
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet 5610 All-In-One InkJet Printer Logo
509 people viewed this question
Ben Johnson
