Question about Nortel Norstar 16-Line PBX Speakerphone
Unable to set up Nortel caller ID on a T7316 Phone
  • Travlin Tech May 11, 2010
    Hi, Do any of the phones on the system now have caller id info coming in? Dan
    Do any of the phones on the system receive caller id info now?
  • 201 Answers
SOURCE: Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Posted on Oct 26, 2007
SOURCE: nortel norstar m7310 phone caller id problems
did you change extension numbers? Or did your extension number move with you?
Posted on May 08, 2008
SOURCE: Template for T7316 Phones
Go here, http://support.nortel.com/go/main.jsp?cscat=SWDETAIL&SoftwareOID=147467, and download the Desktop Assistant. It will allow you to create custom labels for that particular phone and a few others in the 7000 series.
Posted on Jan 07, 2009
consultel1
  • 860 Answers
SOURCE: Can somebody help me in setting up caller ID on my
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
that should do it providing you have caller id service though your local telco provider.
Posted on Mar 26, 2009
SOURCE: call forwarding on t7316 nortel system
turn on feature 84.... turn off feature # 84
Posted on Jun 25, 2009
Is there a way to setup caller id on a Nortel system that show when the phone rings
In system programming, you can select whether the display is the name, number, or line.
F**CONFIG
Terminals&Sets
enter extension #
skip Line Access, Capabilities, Name, User Preferences
Telco Features
skip Feature Assign
at 1StDisplay use CHANGE softkey to toggle to NAME.
Mar 26, 2014 | Nortel Lands Phones
My t7316 is no longer ringing at my desk or showing the caller id
You can set the ringer volume by using Feature *80 and use the volume control to change the level. If this does not get your phone to ring again, then the line assignments will need to be reprogrammed.
Mar 19, 2013 | NorStar T7316 Corded Phone
When i press busy button on T7316 phone it says set in use
Did you mean "Line" in use?
Caller calling Voice Mail probably tied it up.
Tech needs to program Supervision Disconnect for the line/s and Carrier must do the same so they talk to each other.
So when callers hangs up a disconnect signal tells the system to hang up.
90 percent of the time the tech had it programmed but the carrier did not.
Aug 27, 2012 | Nortel T7316E 2-Line Corded Phone
Caller ID not working on my t7316 phone
You can copy and paste this link below to go to a site where you can download your entire manual:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Sep 16, 2009 | NorStar T7316E Corded Phone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Jul 16, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Is the nortel 7316 analog?
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Jun 15, 2009 | NorStar T7316E Corded Phone
Nortel M7310
Oct 25, 2007 | Lands Phones
Nortel Norstar 16-Line PBX Speakerphone Logo
123 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
