Question about Dell OptiPlex GX280 PC Desktop
Dell optiplex 280 ddr2 memory information
I am buiyng a branded system(but refurnished) optiplex 280 2.8 ghz with 1 gb ddr2
i have got several questions
1) somebody told me that this supports only 533 bus of ddr2
if you put 667 unbranded(kingston ddr2) in your system it will fails
2) for 1gb best option is 256 * 4 is this correct
3) what is bus and cache speed
  • Anonymous Feb 13, 2009
    I have dell optiplex GX280 tower , and i install 2GB kingston ram of 800 bus speed , But my pc shown 533 bus speed . Any one solve my problem
  • 104 Answers
Optiplex 280 supports upto 4Gb of memory, for more details on this system visit http://www.memoryx.net/deopgxdeme.html
Bus is that carry data through NorthBridge to CPU at a very high Speed. Cache that retain data in CPU itself for faster access of data and need not to read it (data) from memory. THe faster your BUS speed, the better performance for gaming or video you will get
Posted on Dec 02, 2008
    Scholar:
  • 118 Answers
400 & 533 MHz DDR2 SDRAM.
Best option is to install 1 x 1 of 1 GB or 512 x 2.
its also support unbranded rams if they are compatible.
Optiplex is a very good system in its range...
i recommend it if you are interested to buy.
Kind regards,
  • Dell Master
  • 6,487 Answers
You cannot use drr667 on this computer since it only supportr ddr533, and it will be better if you use one stick of 1GIG RAM since your motherboard supports up to 2 GIG of RAM...
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Where do the cables go on my dell OptiPlex 280 model GHZ 3.0?
Gary,
You can click the link below to view the online manual for the Optiplex 280.
http://dell.to/1w0Wpyk
Thank You,
Dell-Jesse L
Jan 07, 2015 | Dell OptiPlex Computers & Internet
Sir i have dell GX280 system 3.0 GHz optiplex. 1gb ddr2 ram with 80gb sata hard drive. Sir, my problem is this first i brought a system it runs fine but sometimes a day it hangs up. i return this...
Plz check your memory with memtest. It can be downloaded from http://www.memtest.org/download/4.10/memtest86+-4.10.iso.zip .
Unzip the downloaded file and burn the ISO file to a CD and boot your system from the CD. It will check the memory of your system and it will indicate any error replace the memory.
Also check your memory slot is clean .. you can clean your system memory slot using a anti-static brush (you can use a tooth brush if anti-static is not available) and IPA
Sep 12, 2010 | Dell Optiplex GX280 (99301) Motherboard
Pc doesn't start properly, and displays a 1 & 3 on the front panel
Memory modules are detected, but a memory configuration or compatibility error exists.
May 11, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
My dell gx 280 just put new ram
Here is the code,Please make sure the memory you used is DDR2 and please rate this a fixya
Feb 14, 2009 | Dell OptiPlex GX280 PC Desktop
Dell 8400 new memory
If you are using Windows XP, go into your control panel, double click System (from classic view), and look towards the bottom where it says "Processor x.xx GHz, x.xx GB of RAM" and make sure your 2.00 GB of RAM is recognized by Windows. Next I would make sure you are using 400- or 533-MHz DDR2 unbuffered SDRAM. If you are, try removing one of the two modules and see if the computer runs smoothly. If it does, I would install a different brand of memory.
Dec 31, 2008 | Dell Dimension 8400 PC Desktop
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
993 people viewed this question
Alun Cox
