Question about Pioneer PD-M406 6-Disc CD Changer
Laser problem on Pioneer model PD-M530
I replace laser pickup and need to know how to get in service mode?
2 Suggested Answers
  • 13 Answers
SOURCE: Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
use krazy glue to get the arm glued with the cd port or use electrical tape.
Posted on Jul 14, 2009
projdoc
  • 2236 Answers
SOURCE: 6 cd-player (PD-J910M) cannot read any CD. It just
time to clean the lens. any electronics store will sell a cd lens cleaner. if after that it won't read, you need to take the cover off and gently clean the lens with a q-tip and rubbing alcohol. blow it off to dry. if it still won't read, you'll need to replace the optical pickup assembly.
Posted on Jan 29, 2010
Pioneer PD-M550
The player have problem with the laser pickup unit.
Try one thing, there is a disc available for cleaning the laser pickup unit (). You will get in any cd shops(instructions will come with it). Buy the cd and the insert it in any one of the tray. It will clean the laser unit if there is any dust in it. After cleaning put a disc and check is the problem remains. If the problem remains the you have to change the laser pick up unit. You can fin a link here which will lead you to the laser pick up unit. You will get the part only against confirm order.
PEA1030
Laser cleaning CD
Ajin
Jul 24, 2012 | Audio Players & Recorders
Pioneer PD-M40 changes through all 6 cds but does not stop to read any of them
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
Jul 02, 2012 | Pioneer PD-M603 6-Disc CD Changer
Player not reading disc , what could it be
Hello
Just clean the laser pickup unit lens, by inserting a disc cleaning disc. this disc an be bought from most of the electronics spare part selling shops at your town. If it doesn't help you, there is no other way than replacing its Laser Pickup Unit with same type and number. OK.
Jan 15, 2012 | Pioneer PD-F507 25-Disc CD Changer
I have a Pioneer PD-M550 6-Disc changer. When I try to play a disc, it won't spin... UNLESS I turn the unit upside-down. Then it plays just fine. So the lens is fine, but something is keeping it from...
Hi. You need to replace the opu (optical pickup unt), laser in other words. The laser diode is slowly getting weaker and the lens works in conjuntion with the laser. The reason it works when it's upside down is because gravity is pulling the lens closer to the disc, thus it does not need as much power to focus onto the tracks etched into the disc. Replace opu with type PEA1030 aka PU-23 http://www.donberg.co.uk/catalogue/laser_units_cd_dvd/laser_pu_23.html. Hope this helps you out and good luck.
Mar 08, 2011 | Pioneer PD-M603 6-Disc CD Changer
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Jul 05, 2009 | Audio Players & Recorders
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Pioneer PD-M423 CD player will no longer read CD's. For each CD, I hear either a high-pitched buzz for a few seconds, or 3 clicks, then it moves on to try the next CD. Unit was recently moved several...
Have the same problem. Had friend, electronic tech look at it. Pickup assembly failure. Use Partstore.com or Pioneer to find part and then cross reference with other models that use same part. I bought used item on Ebay, $40 to repair my unit. Simple 5 screws, two pug in cables. Be sure to discharge static electricity from body before touching interior parts. Up and running in 20 min,
Dec 30, 2008 | Pioneer PD-M423 CD Player
Pioneer PD-M406 6-Disc CD Changer Logo
166 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
