Question about Whirlpool Duet GHW9150P Front Load Washer
The letters H and then F are flashing about 19 minutes thru cycle
We just moved out washer to a new hook up in the basement and seems like all was well.  I came back down and noticed the letters H and F were flashing alternately. Any ideas as to what this might be?
  • 1 more comment
  • mail689 Dec 05, 2008
    Thanks again, it was sort of a water flow issue but more so dirt that was built up on the screen drom the new pipes installed.
  • Anonymous Dec 05, 2008
    my water is turned all the way on and their are no kinks in the hose my washer is constantly doing this sometimes it works fine others it flashes hf
  • allbro Dec 06, 2008
    I am getting hf constantly I can wash one load and get the hf error I drain it out and wash again and it will wash fine next load hf and then washes fine. This is constant have checked all hoses and water flow everything fine. .
  • 121 Answers
Fh is a water flow problem make sher the water is turned all the way on
Posted on Dec 02, 2008
How di i reset my samsung dryer
Did you give it plenty of time to cool down before you moved it? If not, you heating element could have opened - if everything else seems to work except heat, but you should also check the thermal switch.
Jan 18, 2012 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
My washed flashes F-1 when trying to start the washer and at 19 minutes left in the rince cycle
Just had same problem & its also beeping @ 19 min, I noticed there is alot of complaints about this. 1000.00 almost & its junk! Im calling customer service.
Mar 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Moved my washer and re-hooked it up and now it only runs for a few minutes and then flashes H F what can I do to fix this???
our washer did the same thing. it turned out it did not have enough water pressure to run the wash because our older than dirt water heater was full of calcium deposits and was blocking the water coming thru nearly every entry to the house. we got a new water heater and the problem solved itself immediately.
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My GE front loading washer Model WCVH6260 does not start the rinse cycle spin. It has a motor sound and some water seems to be draining but the rinse cycle does not spin and the motor continues to make a...
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Oct 01, 2009 | GE WSXH208A Front Load Washer
Washer stops at 2 minutes and a letter "f" blinks
I had the same problem. It would flash f then 02,
click this link and you can fix it in about 5 minutes.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Rocking and VIbrating
As long as you have it on the second floor there really isnt anything you can do to fix it anything you do will probably make it worse there is only one washer i know of that is front load and acts decent on the second story and thats the new samsung with the roller bearings. Sorry to tell you but u will probably end up moving it to the basement
Jul 14, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
