Question about Roper RAS8445KQ Top Load Washer
How to get the top off the washer
We can't get the top off our washer so that we can replace a faulty lid switch.
  • Jennifer Clark Feb 01, 2007
    I guess I'm looking for someone that knows how to remove the top of the washer. Is there anyone that knows. Sorry, I've never used this site before.
    President:
  • 878 Answers
Jenlyn. The whole cabinet will lift off. Remove the two screws behind each end of the top consol. Pull forward and lift up. Remove the snap springs and lid switch harness and pull the cabinet forward and off...see the attachments...Catriver..post back.
Posted on Feb 01, 2007
  • Ron Marek
    Ron Marek Feb 01, 2007
    Here you go
Samsung WF42H5400 AW/A2 Washer was briefly unplugged, then plugged back in. Now, it will not power on. Any ideas as to why?
hi Peggy.
Main reasons a washer will not start (either front or top load):
1. Power breaker off, washer not plugged in.
2. Lid switch faulty, door switch faulty.
3. Start switch and or timer faulty.
4. Washer motor faulty.
5. Main control board faulty or shorted.
Power to Washer
Be sure the washer is plugged into the electrical outlet in the wall. Also be sure the breaker switch in the breaker box is turned on. If you live in an older home your box may be called a fuse box. If so, make sure the fuse is in good working condition.
Door Switch Strike (Front Load Washer)
The door switch is a safety feature on front loading washing machines. On front loaders, the door switch must be closed and the door must be locked. If this switch malfunctions, the washer won't start. This switch is in the door frame of the washing machine where the door shuts. If you suspect the door switch is causing your washer to not start, carefully check the strike where it engages into the door lock assembly. Be sure the lock is working properly by keeping the door shut and locked shut. You can check the door switch for continuity with a multimeter. Be sure to disconnect the power to the washer when you check for continuity. If there is no continuity, replace the door switch.
Lid Switch (Top Load Washer)
A lid switch is a safety device located under the lid on top load washers. This lid switch will not let the motor operate when the the lid is open. If the lid switch is faulty, then the washing machine will not start. It may fill with water but will not spin if the switch is faulty. Some lid switches on top loaders also control the water inlet valve. In some top load washers, if the lid switch is bad, the washer will not fill with water. The lid switch is under the lid. There is a pin or pusher attached to the lid. This pin or pusher (when lid is closed) will press the lid switch. If your washer will not start, be sure the switch is being pressed. If the lid switch is being pressed but no power is being supplied to the washers motor, then the switch is most likely bad. To test the switch, turn off power to washer and remove the wires from the lid switch. Check the switch for continuity with a multimeter. If there is no continuity, replace the lid switch.
Start Switch and Timer (Top Load Washer)
The start switch timer on top load washers is part of the timer. This starting switch is turned on by pulling out the timer knob. If after pulling the timer knob the washer will not start, you can test it for continuity with a multimeter. Remove power from the washing machine and find the timer contacts. Some top loaders have a start switch that is a momentary contact type of switch. This switch will be located on the control panel. You can also test this switch for continuity with a multimeter while pushing the button in. Remove power from the washer before testing for continuity. If there is no continuity, replace the start switch and or timer.
Timer Knobs
Sometimes the timer knob wears out and cannot properly engage the timer shaft. If this is the case, then the knob is at fault. The knob cannot grip the shaft therefore is unable to turn the machine on. A worn knob will cause it to slip. Turn off power to the washer and inspect the back of the timer. Make sure the timer shaft engages the knob when it is pulled in or pushed out. If the knob is worn, replace it with a new one.
Drive Motor
Both top and front load washers use a motor that spins and agitates. (A top load washer uses a reversing motor) The motor spins in one direction to agitate and the other direction to spin. When the wash motor will not turn on it may be faulty. If the motor makes strange humming sounds then the motor may be at fault. To test the motor, remove the belts and try to start the motor. If it runs then you know something else in the washer is causing the issue. On newer direct drive washers, you will have to disconnect the pump and the coupling to the trans. If the direct drive motor turns on, then then you have a transmission issue or possibly the pump. If the direct drive motor won't start then it should be replaced. On front load washers the motor drives the washing basket with a ribbed belt. Remove the belt and try to start the motor. If the motor runs, then be sure the basket turns and doesn't have anything stuck or jammed between it and the outer tub basket.
Main Electric Control Board
The control board controls every component in your washer. If the main control board does not properly control the motor, the filling valve, the drain motor, or the door lock, the washer will not start. The only way to determine if the control board is at fault is to visually inspect it. Check for burned areas or any component on the board that may look burned or damaged. If you find burned areas or components on the control board, remove and replace it.
or read up more at this link.
samsung washing machine will not turn on Google Search
Dec 12, 2017 | Samsung Washing Machines
Waher fill run but thats all don,t spin don,t wash dont risen
The most common cause for this problem is a faulty lid switch! this the switch that gets depressed by the tang on the machine lid. If the switch is problematic, or faulty, the washer will only fill and that is it! The timer will not advance or the motor run. The switch can be checked with an ohmmeter, and they are fairly simple to replace. If any further information regarding machine disassembly and switch replacement is needed, feel free to post here again.
Hope this gives you a starting point.
kcomp1863
Jan 19, 2011 | Roper RAS8445KQ Top Load Washer
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top load Kenmore Elite Washing machine that runs for 5 seconds then stops for several minutes. This pattern repeats. It just started yesterday. What is wrong with it? I have unplugged and...
Sounds like the timer is faulty. Or you lid switch is out of wack. Try leaving leaving lid open and placing a screwdriver in switch located where the lid clip comes down into washer. If this works the switch will need replaced. Timer is another story as you will have to remove top panel and replace timer if the lid switch is not the cause
Mar 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer will work on rinse, then stops, won't drain or spin.
most likely the lid switch is faulty .there is a tab on the washer lid that lines up with the lid switch make sure it is lined up and switch is depressed . should hear a click ,if not replace switch.
Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Motor comes on and water gos out but basket will not spin untill lid is opened then closed again . this is on all spin cycles .
HI, you will need to replace the lid pressure switch. it is faulty or the wires may be worn or lose.in most cases, it will be a faulty lid switch.
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer top load
FAULTY LID SWITCH, LEFT TOP AND REPLACE IT
Nov 30, 2007 | Kenmore 22422 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
167 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
