Question about Zyxel ZyAIR B-100 802.11b (AM5009004) Wireless Adapter
Please help hi i am having problems connecting with this product it has worked fine previously but has now muched up when i open the wireless utility there are only 3 tabs rather than 5 also i cant see where i am ment to enterr the network key? i know the network im connecting to needs one also i cant view availible wireless networks via windows it may be really simple i just cant see anything
  • 611 Answers
Re-installed the driver after then it not working then download the driver the driver in zyxel.com
Posted on Dec 12, 2008
I can not turn ON My Intel wifi Radio , it shows in the bottom right corner but when you open it it is off and Grayed out , unable to hit enable . Have tried several remedies that did not work and this...
It seems that the Windows wireless utility is active on your computer. Try to open the Wireless Network Connection properties on your computer. (Start > Control Panel > Network Connections > Internet Connections > right click on the Wireless Connection > choose properties ) There should be a Wireless Networks Tab. Un-check the option that says use Windows to configure the wireless connection. That should allow you to use your Intel wifi-Radio. But personnally, I would prefer to use the Windows wireless manager that any other wireless utilities.
Please refer to the pictures attached to be easily guided
Jul 04, 2011 | Computers & Internet
Router was working fine, then I upgraded the fw level to .29. When I did that, I could connect my 2 wireless laptop connections, but the 2 desktop pc's will not connect to the internet being wired. I have...
I hope you have a Belkin F5D8233 ver :3000 wireless router and you have upgraded the firmware version: 3.01.29.
It's a known issue with this model , only the wired connection will be not be online. Another information when you connect the computer in the 1st LAN slot you will have internet connection but not with other 3 LAN slot on the router. To fix this please follow these steps,
1. Log into the Belkin router setup page (http://192.168.2.1) in a wired computer .
2. In the left hand side under the heading Utilities? click on save/backup settings
3. When its asking for password to login leave it blank and click on submit.
4. Click on save to save the settings of the router in the Desktop
5. Then again under Utilities? click on restore factory defaults and then click restore defaults button, to restore the settings of your router to factory settings.
6. Then Under Utilities click on restore previous settings and select the file where you saved it and click on restore settings.
Then automatically you will be able to go online both wired and wireless.
I'm sure this would work. If it does work then please rank me and give me a testimonial
Thanks in Advance!
With Regards,
Prema.
Jan 03, 2011 | Computers & Internet
I recently purchased this. (http://www.newegg.com/Product/Product.aspx?Item=N82E16833127272) and a copy of Windows 7 64-bit OEM. So, I go to install the utility and drivers and after the point where it...
Did you try these drivers for DWA-125?
ftp://ftp.dlink.com/Wireless/dwa125/Drivers/dwa125_drivers_120.zip
If your model is DWA-125 RevA2 then you need these drivers for it.
ftp://ftp.dlink.com/Wireless/dwa125_revA2/Drivers/dwa125_revA2_drivers_130.zip
Uninstall all the previous drivers/ apps related to your adapter. Download the appropriate drivers above. Unzip/ extract the file. But don't run any installer yet.
Plug in your adapter first cancel the windows new hardware found pop up if it come up. If windows says no drivers found thats ok. If windows finds the drivers and installs it right then great if not then lets move on.
Open device manager. Click on the adapter and click upgrade driver and select find drivers manually. Point it to the folder you unzipped all the files too. And windows should install the drivers this time.
Let us know how it goes..
Apr 02, 2010 | D-Link DWA-125 Wireless 150 USB Adapter...
Laptop doesnt connect to wireless internet (wireless card is fine
When you reformatted your HD, did you use IBM's method which utilizes a hidden partition? This results in a laptop which appears to be as if it just came from the store, like a brand new laptop.
This method sets up the computer in the exact way that IBM built it. And puts all devices in their proper configurations.
If you have not done too much yet, you might want to try that method right away and see if it doesn't make a big difference in the way your laptop works.
-a.
Feb 19, 2010 | IBM ThinkPad T42 Notebook
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
Cant connect to secured wireless network...
Hi Grant,
If it says aquiring acquiring network connection while you connect to the wireless network it means that something is conflicting with the wirelss network, so first you have to check wether 2 wireless utiliies ( windows wireless utility and dell utility )are active at the same moment, if yes disable one of them and try again, still if it does not connect, disable antivirus and firewall and check if that fixes the issue, still if it does not work then try changing the security type on the routers page, basically this should work out and still if u have any issue, please reply to this msg for further troubleshooting steps....
And even if it gets resolved please reply once.
Thanks and Regards
Anup
Apr 01, 2009 | Dell Wireless 2350 Router
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless network not detected despite all elements seems working
Hello there.
This is a common problem. What i typically do on notebooks that use Intel Wireless, is install the latest drivers and Intel software from their website. 9 times out of 10 this will make it pick up a network that was not previously found, or fix problems with timeouts and so on.
Please click here then choose your version of windows, click 'Go!' and then click "Download" beside the section called "Intel® PROSet/Wireless Network Connection Software for Windows* XP/2000 32-Bit"
When you download and run this file, and install the software, you can then use the Intel utility to connect to the wireless network.
Hope this helps.
Jun 16, 2008 | Intel PRO/Wireless 3945ABG Network...
Not satying connected
Try using the Window built in connection utility. Open up the belkin softwar, click on the 3rd tab and select, use windows. See if that works
Jun 04, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Having to re-enter shared secret key in client card utility
With the description you have provided, I presume that you are using Windows XP. Now, whenever we use utilities to manage wireless adapters, they always conflict with the Wireless Zero Configuration (A service in Windows XP which manages your wireless adapters) and mostly your utility is not able to retain the settings provided to it. The best solution would be to disable the Utility and use the Wireless Zero Configuration instead. We can do that by right clicking the icon for the utility which must be available in the system tray (on the right bottom corner of the computer srceen) and there must be an option which says something like - 'use windows to manage the wireless adapter'. Once we do that, we need to make sure that the Wireless Zero Configuration is actually enabled. Please follow the following steps. STEP 1: 1. Click on start -> run 2. Type 'services.msc' and click OK 3. This will display a list of services 4. Try and locate the 'Wireless Zero Configuration' in the list 5. Double click on it 6. Make sure the 'Startup type' is set to 'Automatic' and the status is 'Started' STEP 2: 1. Click Start -> Control Panel 2. Locate the icon - Network Connections (when in classic view) 3. Under Network Connections, right click on the 'Wireless Network Connection' and click on 'Properties' 4. Look for the 'Wireless Networks' tab 5. Look for the check box which says 'use windows to configure the wireless network settings' Any further questions or issues, please get back to me. good luck
Mar 22, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
Zyxel ZyAIR B-100 802.11b (AM5009004) Wireless Adapter Logo
116 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
