Question about Brother MFC-8440 All-In-One Laser Printer
Problem reinstalling Brother MFC 8440D.
I am reinstalling my Brother MFC-8840D. The PC (Win XP) is now able to print to the MFC (connected via USB) but the Scansoft Paperport wouldn't install. I tried Uninstalling but when I tried to re-nstall the only choice is REPAIR OR REMOVE. BUT my main problem is that I cannot see the MFC under Scanners and Cameras. What do I need to do to fix this?
    Champion:
  • 320 Answers
Uninstall the brother software for this machine, then reinstall the softeware. the paper port some times will install automaticly or you may have to click on iy to indtall. brother tech
Posted on Jan 14, 2009
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Just got a new computer w/windows 7 and now my brother mfc-8840D won't scan to pdf now? Any ideas on a solution to fix?
How to get a MFC-8840/D/DN to scan to Windows 7 over the network or by USB:
First - Download the Windows Vista Full Driver & Software Package from Brother: Brother MFC-8840DN driver download page
Install the drivers using a custom install - pick only the Network scanning drivers, unless you want the other junk - no promises on how well the other stuff works.
Alternatively, if connecting the MFC-8840DN to Windows 7 by USB, download the Printer and Scanner Driver for Local Connection. It is a separate download. Install only the Scanner driver.
Once the Vista scanner driver is installed, you can test by running the built-in Windows 7 Scanner Wizard. Here are instructions on how to test.
As far as conversion to PDF, that will depend on the software. I am not sure if the Control Center or Paperport softwares work on Windows 7. I have not tried those. I have found that freeware STP will works fine.
Here is a link to the STP homepage.
Here is a link to how to use STP with the Brother MFC-8840DN
May 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Feb 25, 2009 | Brother MFC 8840D All-In-One Laser Printer
Putting out extra sheets
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Feb 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
What is the exact problem with reinstalling the Brother MPC?
Is it the printer driver or the cable connection?
To install the printer drivers, just insert the CD that came with the printer into your computer and follow the on screen instructions.
Nov 28, 2008 | Brother MFC-8840D All-In-One Laser Printer
Mfc-210c will not print
do you run mac or win as a pc system?
for pc: delete all drivers by help of the agressive remover tool (see: www.brother.com choose your country, your mfc and download the drivers needed).
Take mfc from power outlet and disconnect from usb port. Run the above mentioned procedures and reinstall the drivers again. When asked, replug mfc to power again.
Connect the usb cable directly to pc!!!!!!
If you run mac I cant give you an adivece yet, because I m not common to mac os yet (end of year I will know better cause will get an imac then, sorry!)
Apr 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC 8440D FAX VOIP
You should change the Baud rate to 9600 on the machine. This should correct your issue.
Also call vonage and they have some settings they can modify to improve performance.
Mar 31, 2008 | Brother MFC-8840D All-In-One Laser Printer
Can not get my printer to print from the computer
Unfurtunately you didnt tell us what pc system you run: Is it XP, Win2k or Vista?
The latter one wont be able to connect to your pc.
For the mfc 210c are only drivers for xp and win 2k, 98se avaiable.
You need another (newer) mfc (mfc240 or 235) if you run vista.
Anyway, if you run xp, download the aggrssive usb driver remover from the brother homepage and delete the drivers installed.
After a restart of the pc do have the mfc DISconnect from usb port (which must be one of the pc: NO hub!). Insert install disc and wait until pc software demands the connection to mfc. Connect now to pc usb. Let the software finish the installation. This should work for xp and win 2k/98se.
Mar 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Scanner not being recognized
Knowing your PC-System would be helpful: Is it Win (and what version) or is it Mac?).
Did you connect to a USB-hub? This wont work! You have to connect directly to a USB-port of your PC.
Do connect only by a USB-cable NO longer than 2-3m!
Jan 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-8440 All-In-One Laser Printer Logo
134 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
