Question about Lexmark X2350 All-In-One InkJet Printer
Does not printer
When I turn it on it make a sound. The sound is that the cartilge run from one side to the other side of printer and does not printer and a long plastic came out of it.
    Genius:
  • 2,120 Answers
It sounds like an ENCODER STRIP, not worth fixing.
Posted on Dec 02, 2008
Hp t1100 grinding noise after print
I suggest you run the diagnostics for the printer which allows you to isolate and run individual components. That way you can see which item is causing the noise. If it is coming from the left side, you might have a problem with the cutter.
Dec 17, 2016 | HP Designjet T1100 Photo Printer
Making noise then displaying error asking to turn printer off
Just we cant judge reading the sound if we hear the sound we can say the fault, any how check fuser assembly seated properly or not? open side doors then observe where you are getting the sound..
Jan 30, 2012 | HP LaserJet 4600 Printer
My printer has a paper jam but there is no paper jammed in my printer what do i do?
run the roller cleaning application in maintenance a few times then turn your printer upside down and gently shake it side to side to clear any foreign objects that may have fallen down the paper feed.
I know it sounds silly but on 3 occasions now i have cleared the "jam".
Nov 30, 2010 | HP Office Equipment & Supplies
My A920 dell printer was working fine, I cleaned the inside (gently slid the print head/cartridge to the side) Now it just bangs from one side to the other when I turn it on?
Sounds like the clear stripe that runs behind the cartridge holder is not feeding through the senser that recognizes where the cartridge is. Realign stripe and it should be ok.
Jun 06, 2009 | Dell 922 All-In-One InkJet Printer
When i print from the brother hl2040 printer there is a ink spots running down in the page. how can i fix this problem?
It sounds like you have damage to either your transferr roller of the drum, you could try running a laser printer cleaning sheet through it a couple of times but usually the only way to sort the problem is to replace the part that is causing the problem.
Take the drum out and turn it by hand using cog at the side to turn it to see if its marked.
Jun 04, 2009 | Brother HL-2040 Laser Printer
HP 2210 Printer - Scanner sounds like it is stuck
It's possible that the mylar strip has become contaminated with ink and/or dust or is loose.
The mylar strip runs horizontally along the length of the printer. It threads through a slot in the carriage and is connected by hooks on both sides. Make sure that it is still connected on both sides.
If it is connected properly on both sides, try cleaning it. Gently rub a moistened lint-free cloth back and forth across the strip. The easist method is to squeeze the strip between your thumb and forefinger along with the damp cloth.
If the strip is not loose and cleaning it does not cure the problem, you'll probably need help from a certified HP technician.
Mar 25, 2009 | HP PSC 2110 All-In-One InkJet Printer
Cartilge Fails
it means that the cartridges have some prob, either its defective or need to clean, cartridges is the ink container, which holds the whole color, separately into two, one is black the other one is MCY or color
Dec 21, 2008 | HP Photosmart A617 All-In-One Printer
Lexmark X3470 carrier jam. Turn on and carriage slams from side to side.
sounds to me that the carrier dont know its location check to see if the plastic indicator srip cable that runs from the right side of the printer atatched to a small spring through the back of the in carrier to the left side of the printer attached to a metal tab this will be all inline from right to left if this cable came off.. it will have the same symptoms u discribed, hope this helps
Jul 14, 2008 | Lexmark Office Equipment & Supplies
Printer wont feed paper on one side
This may sound strange, but it works more often than not. Try unplugging it, turning it upside down and shaking it vigorously. Also, take some canned air and spray into where it feeds the paper. Just be careful not to spray into the ink-head.
Mar 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
PROBLEM BROTHER 2040 PRINTER
Have you replaced the drum and toner? It sounds as if the printer is saying it's time. The motor constantly running usually means it's trying to add toner to satisfy the toner sensor, but it's empty.
May 29, 2007 | Brother HL-2040 Laser Printer
Lexmark X2350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
