Question about Samsung SGH-E570 Cellular Phone
Camera displays sensor disconected
When I try to use the camera it displays the error message (sensor disconected) has any one had the same or can anyone advise on the problem
  • Anonymous Feb 05, 2009
    I have the same problem ! And I am very surprised to see that someone else has the same problem as I.
    I have tried to reset my phone but that didn't helped.
    I am still trying to search for a sollution.
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
I have a Sony DSC-T1 and it is displaying a flashing error message E61:10. . The screen is blurry and I can't do anything! It had the CCD chip replaced by Sony free of charge previously - is this the same...
In DSCT1 Camera, the E:61:10 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. The E error code indicates the internal hardware malfunction with the Camera. This issue is not related to the CCD Image Sensor replacement.
Try the steps given below to check if the issue can be resolved.
· Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also, try resetting the Camera back to factory default by pressing the RESET button using a sharp-pointed object. The RESET button is located at the lower right side of the control buttons.
Please make sure that the Camera is turned ON before you reset it.
Good Luck!!
Nov 09, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
AG-DVC30 "no tape in camera" error message
thats probly the cass in swicth
or a dirty sensor....
hope that will help..
Mar 01, 2010 | Panasonic AG-DVC30 Mini DV Digital...
Error message on nissan xtrail car radio wont return to code in put message been 3 days since battery disconected tryed disconnect again no change
If you have the anti-theft code (it's like a business card attached were you find the code and direction) just follow the directions to enter the code but if you don’t have it, here is a link to get it
Jan 05, 2010 | Car Audio & Video
I have a constant error message displayed. The
I have the same camera, but never had this problem. I think there's something wrong with the shutter mirror or worst, the sensor. Did the viewfinder blacked out when you press the shutter? I think you need to bring it to Nikon repair shop....
Oct 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Samsung SGH-E570 Cellular Phone Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
