Question about Dymo LetraTAG Thermal Label Printer
The letters are coming out really faint if at all on the tape.
How
  • 1 more comment
  • icmartin Dec 17, 2008
    Mine will print borders fine...just no text....weird.
  • ARNMJA Jan 14, 2009
    same
  • Anonymous Jan 19, 2009
    Letters are faint and missing
Try changing the battery.
Posted on Jan 06, 2009
Selectric II type ball not rotating. from what i can see, the cables are all on their pullies. Every number letter and symbol come up wrong. Some letters type on top of each other and come up slightly...
Maybe the rotate tape slipped off either the left or right side pulley. You need to remove the platen and upper case half to fix it. If the tape (thin eighth inch metal tape that when pulled on slightly rotates the ball) is off either pulley, very carefully, without lessening tension on the tape, try to slightly rotate the ball counterclockwise which will loosen the tension on the tape and slip it back on the pulley.
Jan 11, 2010 | IBM Office Equipment & Supplies
My Toshiba DVR670 dvd recorder/vcr combo. When I turn on the combo and have a tape in it it will display in the bottom lefthand corner the letters SP and an arrow pointing up with a line under it above the...
need to repair or replace the unit more likely the VCR belts are not tight enoughsince the advent of DVD recorders the quality of VCR components has gone way down I have 3 combo units the only one that still records is in the unit which only has a DVD player in it. and even that won't allow tracking adjustment
Dec 07, 2009 | Electronics - Others
Samsung mini dv VP-D101 poor recording
that issue will come to any camera these days , you know what to do , you go to you local shop(wallmart or something) and ask for a cleaning tape its not very expensive and make sure that the tape is dry then put it where you put your tapes in the camera and play , and eventually the picture will get good again ...god bless ya and good luck=)
Aug 09, 2009 | Samsung VP-D101 Mini DV Digital Camcorder
Solution for "why is my hp photosmart 8150 printing part of the page in black letters and part in red letters
Check if the cartridges have enough ink for printing.
Perform a print in different colors and see which one comes faint.
Mar 05, 2009 | Office Equipment & Supplies
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to...
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Aug 21, 2008 | Kodak Office Equipment & Supplies
Printer is printing every line two times and is faint
if you said you have done and removed the tape and run all test, chances are the cartridge itself is the problem , return to vendor for a new replacement, this can sometimes happen
Jul 23, 2008 | Dell 922 All-In-One InkJet Printer
Skipping parts of the letters
If the ribbon isn't moving a full space for each letter printed try code . or , this changes yhe spacing.
DickyO
Feb 19, 2008 | Nakajima AE-740 Typewriter
Correction function not working
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
Random letters/correction tape
You must have damaged the Daisy Wheel when you were fitting c'tape..Fit another wheel..
Apr 10, 2007 | Brother SX-4000 Typewriter
Dymo LetraTAG Thermal Label Printer Logo
48 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
