Question about Dell Dimension 4600 PC Desktop
I nned to find out how to buy an ethernet adaptor for a Dell Dimension Desktop. It is 383 MB RAM and 32 bit File System. thanks
    Problem Solver:
  • 5 Answers
The Dell 4600 comes with a built in RJ45 connector on the motherboard, you don't need to fit another one unless you have a specific reason to. e.g. its stopped working, you want a giga speed card, you want a second card to create a firewall/dmz.
Here are the specs
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
Posted on Dec 03, 2008
  • Dell Master
  • 6,487 Answers
You can just buy any ethernet adapter in the market like this one from Linksys LNE100TX or a NC100 it will work fine for your computer.....
Posted on Dec 02, 2008
    Problem Solver:
  • 17 Answers
You can buy a pci ethernet card and put it in a free pci slot. Install the driver and it should work.
I wish to upgrade my PC with windows 7
Depends on your Hardware.... if it is a slightly Older Computer then chances are it is a 32 Bit.... but if it is one to just a couple of years old... it COULD be a 64 Bit......
Regardless of if 32 or 54 Bit the Computer WILL run on 32 Bit Win 7.
and again regardless of 32 or 64 bit,.... 32 Bit Software SHOULD run on it without problems, but you may have to set it to "Compatibility Mode"
Good Luck
Jun 03, 2014 | Dell Dimension E310 PC Desktop
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
MAXIMIM Ram You Can Put In A Dell Dimension 5000?
Your PC can support upto 4GB of RAM incase you are using vista or Windows 7 and if you are using win XP (32 bit) then only 3 GB is supported 1GB shall standby and also make sure that they are not more than 533 HHz
Kindly rate this solution
Thanks And Regards
Feb 24, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I would like to buy a new dell but not sure how much memory i would need. I don't recall how much memory is in my previous dell. It is a dell dimension xp. Would you please let me know how many GB there...
With any new computer you should get 4 GB of memory, the more the better. There are two version of Windows you can get 32 or 64 bit. The 32 bit version of Windows has a 4 GB maximum on the memory, the 64 bit versions go much higher depending on the version you get. 4 GB will give most people more than enough to do what they need. To see how much memory you currently have just Right-Click on the My Computer icon and select properties. In the window that comes up you will see the memory you currently have.
Jan 30, 2010 | Dell Dimension 3000 PC Desktop
I added 2 mb memory to my 2 mb dell dimension c521 but it only shows 3.25 mb memory on my desktop when it should be 4.00
This is normal. You need a 64bit Windows if you want to see a bit more. The graphics can take up quite a bit of memory space.
Jan 03, 2010 | Dell Dimension C521 PC Desktop
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
I upgrade the memory of a Dell Dimension Desktop 9150 from 512 MB to 2 GB,The machine accept up to 4 GB..In the BIOS appear the 2 GB but on system in Control Panel only shows 512 MB..Can anybody give me a...
No you don't have to install a 64 bit OS. Only if you install over 3 gigs you MUST install a 64 bit operating system. 800MHZ is fine it will just back down to 667MHZ. your 32bit windows OS will see up to 3 gigs (minus graphics card memory). SO 2 gigs will work fine. Install one stick at a time and check in the OS and bios to make sure each stick works. I would say you possibly have a dead ram stick.
Jun 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
32 bit RAM usage ?
Due to addressing limitations you will not be able to utilize all 4GB. You can remove the 32 bit OS and install a 64 bit OS if you want to, but I don't think it is needed. Your computer will run great and should recognize and use between 3 and 3.5 GB, possibly slightly more.
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
Want to kow how much ram I can add and where to buy it.
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
May 16, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 4600 PC Desktop Logo
73 people viewed this question
Alun Cox
