Question about Uniden BC796D Base Scanner
BC2500XLT Not picking up any signal
I have a BC2500XLT. and I am unable to pick up any transmissions with the exception of really high frequencies, like in the 900+MHz range.... I am using the stock rubber ducky that came with it. the only way to get it to stop scanning is to open the squelch all the way. this scannner seems to have gotten a lot of use, perhaps it is a component failure? or maybe a bad antenna connection?(as High frequencies do come in) i contacted Uniden and they do have a Service Manual, I just have to pay $35.....There is a BC3000XLT Service manual online for free....but I am pretty sure these are two completely different animals on the inside.
SOURCE:
MarkDay
  • 111 Answers
SOURCE: uniden bc898 extend
No, it is not possible to restore these frequencies, The only services that should be in this range (at least in the USA) are radio-control for model airplanes and broadcast FM radio.
Posted on May 15, 2008
kditterline
  • 127 Answers
SOURCE: How can I program a Uniden scanner for the 849.0125-868.9875 MHz
you my live to far to pick it up, or a few months ago some police went digital and if yours has the your will need the new frequencys.
Posted on Apr 17, 2009
  • 160 Answers
SOURCE: BCT 15 scans through to FM
the 2 buttons on top next to the display, 1 is for police, dot and the other button hp,bt. press them until all 4 pol,dot, hp,bt disappear on the bottom of the screen
Posted on May 18, 2009
audio20
  • 22 Answers
SOURCE: Won't pick anything up (uniden BC72XLT)
Not sure this would be a solution but...
Make sure you don't have the Ch. Locked out so it just skips them..
You may also try and let the scanner sit on one frequency that you know has chatter and see if you receive.
This unit also picks up local weather try that feature and you can tell if you reception is working or not.
Posted on Jul 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: My uniden bc80xlt handheld scanner
Sounds like you may have accidentally pressed the "LOCK" button. If there's a "key" icon showing, press the LOCK button at the bottom left of your keyboard, and hold it in until the icon disappears. In case you need it, here is a link to the operating manual for your scanner:
http://www.uniden.com/pdf/BC80XLTom.pdf
Posted on Nov 22, 2009
How do I set up a uniden BCT15X
you may have to do a manual scan..or find out what frequency the different companies and police ,fire and airplanes use,,then you may need an outdoor scanner antenna,,the small antenna that comes with the scanner only picks up very strong signals,,,to program the scanner you may have to search online for programming info,,,,good luck
trevor 320
Mar 07, 2015 | Uniden BCT15X Beartracker Scanner
Sennheiser Wireless Headphone picks up unwanted transmissions
This headset uses a 900 MHz frequency for connection from the headset to the base.
You will always incur lots of interference in a busy office using that frequency band. Any antennas on the roof or close by?
Amateur radio users?
The other thing, you might have a faulty power supply or "dirty power" coming into the unit. You can try and isolate in a current regulating power bar and see if that helps.
Else, consider changing technologies and moving to, say a DECT band.
Avoid, 2.4 and 5 GHz bands as they are in the wireless devices range and likely will incur equal amounts of interference.
Jan 08, 2014 | Sennheiser RS 120 Consumer Headphones
Scanner won,t pick up signals
you need to turn back the squelsh untill the scanner stops and you have to enter the frequencys manualy to get them you will have to go on googles and search for scanner frequencies
Feb 22, 2013 | Radio Shack Pro-95 Handheld Scanner
Unit is an AKG SR40 Dual Pro Wireless receiver, PT 40 transmitter. 662.3Mhz operating frequency. The right side channel is hypersensitive and indicates that it is picking up a signal when the transmitter...
I would suggest that you change your operating frequency. The antenna being removed suggests that the receiver is picking up interference on that frequency. This frequency is in the UHF TV band, and although analog TV no longer exists, digital TV still uses some of the frequencies.
Nov 04, 2017 | AKG Radio Communications
Please advise me what to do: recently I moved to Hungary with Sony TV Bravia KDL-40VL130 bought in the USA. I thought that this advanced TV would work anywhere in the world. However, it turned out it is...
Sorry u can't use this tv,because the US,Mexico and Canada tvs use a signal which run in call the NTSC signal frequencies.The European Union,Asia and the Middle East tvs use a signal which run in call the PAL signal frequencies.So,Pal or NTSC tvs signal frequencies can't not be mix.Can't modtifies these tvs it a PAL or a NTSC tvs and all it eclectronics circuitries run on that signal design frequencies.Those tvs,that call regions free tvs,Those tvs are design to run all over the world.Run on NTSC or PAL signals frequencies.
Oct 24, 2010 | Sony KDL32L4000 32 in. LCD HDTV
BC244CLT Base Scanner: scanner stopped picking up all freq...
If your Scanner has a button labeled ATT or Attenuation try pressing the button, Attentuation is used to block out extremely strong signals and would be used when you are really close to a Transmitter that is transmitting on a frequency close to yours so you can pick up more distant Transmitters.
May 18, 2010 | Uniden BC244CLT Base Scanner
Need to use my car radio frequency for my dvd (make is unknown) player but can't figure out which station!
You want to pick a frequency where there isn't an existing station, so the radio will have a clear signal from the dvd player.
If the DVD player only has a few frequencies to choose from, then tune the radio to each one (with the DVD player turned OFF) and see which one has the most static and the least signal from radio stations in your area.
If the DVD player can be set to any frequency, then just pick a frequency (usually down on the "88" side of the FM band) with the least local signal, then set your DVD player to use that frequency.
Does this make sense? Feel free to ask questions with the "add comment" link.
If this solves it for you, please be sure to hit the "thumbs up" for me!
Feb 09, 2010 | Farenheit DVD-36 Car DVD Player
Jun 23, 2009 | Uniden BC72XLT Handheld Scanner
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Oct 13, 2008 | Kaito KA1103 SW/FM/AM Radio
Uniden BC796D Base Scanner Logo
156 people viewed this question
Top Uniden Radio Communications Experts
Jason
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
