Question about Nintendo Wii Console
My wii remotes wont sync
Two of my remotes work but the other two don't but when i try to sync the others nothing happens if tried using a wii remote charger and replacing batteries but noting works
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
Wii Remote wont sync with the Wii
open the battery door on the remote, theres a red button. also there is a red button on the wii in the SD card slot press the one on the Wii then the one on the Remote.
Nov 28, 2013 | Nintendo Wii Remote Controller
The control lights of my wii just keep flashing but the controls don't do nothing to the wii, I try new bateries and still don't work
First, remove the battery cover for the Wii Remote
Then open the small panel on the front of your Wii console
While holding down the sync button on the controller, press the sync button located under the small panel on the console, wait a moment, your contoller should then be synced.
Jul 22, 2011 | Nintendo Wii Remote Controller
My wii remote wont turn on, i even tried a couple different new batteries but still no lights or anything
Have you tried syncing the Wii remotes? To sync, turn the Wii on, open the back of the remote and then press a red button that says "SYNC". Then open the SD card slot in the front of the Wii and press another red "SYNC" button. If you do this, your Wii remotes should be able to turn on.
If your Wii remotes still don't turn on, visit support.nintendo.com
Or call 1-800-255-3700 for assistance on your Wii.
Sep 23, 2010 | Nintendo Wii Remote Controller
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
My wii controller wont sync with the wii console......what can i do? I've tried holding down the sync button while pushing 1 and 2 etc but nothing is working =(
The Wii Remote Controller should be used between 3 to 10 feet from the TV. ... After holding the SYNC Button on the Wii console down for at least 15 seconds ... This can vary greatly based on certain factors, such as Wii Remote Speaker ... Failure to do so could cause damage
Apr 13, 2010 | Nintendo Wii Console
NO CONNECTION OF REMOTE WITH THE WII CONSOLE
try re syncing remotes and move your sensor bar to the edge of your tv so that it hangs just a little bit. you should hopefully see positive results
Jun 30, 2009 | Nintendo Wii Console
Remote wont work when trying to connect to wii menu
There's two things I know of that could be causing this: either the batteries are too low, or the remote is no longer synced to your console for some reason. The batteries are easy enough to check--just replace them and see if the problem is fixed. If that doesn't work, try resyncing your remote. Each remote has to be synced to your particular console, and won't work on any others. There are buttons you have to press on both the remote and the console that sync the two together--there should be detailed instructions in the Wii manual.
May 09, 2009 | Nintendo Big Brain Academy: Wii Degree for...
Wii remote not working
it sounds like it could be faulty but I got this info from nintendo's website and at the bottom there is a customer service phone number that will help with any other problems relating to remotes for the wii
Still having problems? If the basic guidelines above did not solve your problem, the more specific information below may help.
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
      2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
I know this says if your console does not recognise your remote, but they should be able to help you with your problem too
Dec 28, 2008 | Nintendo Wii Console
Remotes not working
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
159
Dec 16, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
108 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
