Question about Woods INDUSTRIES 83660 OUTDOOR SECURITY LIGHT TIMER
Defective christmas light timer
I have a Darkness Sensing Digital Timer for my Christmas lights outside. It has a digital LED readout and several settings for on at dusk/off at dawn, on immediately/off in XX hrs, on at dusk/off in XX hrs, etc etc. I have used it before and it works great. Today I tried it and no cigar. The digital modes all select normally but the LED readout flashes and no power is going to the lights. Any ideas?
  • 6 Answers
SOURCE: I installed a dusk-till-dawn switch on a light.
Make sure the sensor's eye is pointing North
Posted on Dec 07, 2009
SOURCE: How to set utilitech wall timer for dusk/dawn
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
Posted on Nov 08, 2010
SOURCE: purchased this timer (Woods Digital
Woods 59203 manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
If this is not your timer, add a comment or look through Woods page
http://waterheatertimer.org/Woods-timers-and-manuals.html
Most of the plug-in digital-programmable timers have rechargeable battery.
Some have a AAA battery that is replaceable, but most do not.
59203 has rechargeable battery.
Battery is not replaceable.
Plug timer into wall for 1/2-1 hour.
If display does not show, then battery did not recharge.
Either timer is broken or wall outlet does not have electricity
Posted on Dec 05, 2010
SOURCE: Will the HB51R have to
The dawn to dusk feature is activated by photoelectric eye that senses when it gets dark.
If you put timer in a dark room, it will turn ON ... let's say to operate Christmas tree after you leave a room for the evening.
But if room stays dark, the timer will not sense when to turn off unless you also set timer to turn off 1-9 hours after ON.
That being said, a Christmas tree might make too much light for the timer's photoelectric eye.
Make sure photoelectric eye is turned away from direct light.
Posted on Dec 14, 2010
SOURCE: I have a Woods Outdoor
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
If this is not your timer, add a comment.
A number of folks are writing in about dusk-dawn-timers flashing.
The manufacturer suggests turning photo-eye away from all lighting when installing timer.
Always aim photoeye toward dark region of yard.
I would unplug the timer and let it reset.
Try timer again, turned away from lights so there is no feedback.
Put black tape over photeye and see what happens.
If timer still doesn't work, then timer is defective.
Maybe photoeye circuit was overwhelmed by intense light converted to electrical input.
I test timers, and 4-6% arrive defective, and most last just a season or two, and then you buy another, but the price is affordable.
Local Home Depot sells the GE 15107 outdoor yard stake or wall mount.
I bought one tonight for testing.
It has no photo eye
It has a dial timer where you set exact on-off times by moving plastic segments on dial perimeter.
For example set timer for ON at 5:30 and OFF at 6:00 am depending on your latitude north or south.
geno_3245_189.jpgphoto eye on yard stake timer
Posted on Dec 16, 2010
Testimonial: "Thank you so much for your feedback to my question. I will try your suggestions. If they fail, I will buy the type of timer you recommend! :)"
How do I program my light sensing timer. Model 15158
a timer so when you set the time the lights will automatically go on everyday at the same time
Dec 15, 2014 | Hardware & Accessories
In the "off" mode there is power leakage as some of the LED Christmas lights are still on
1) Buy timer that is rated for inductive, and not just rated for tungsten or resistive.
Rating usually appears in each product manual except with cheap knock-off timers or older timers that might not show rating or have rating sticker on timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Digital timers work differently than mechanical timers.
Digital do not completely shut off the circuit, unless they are rated for inductive.
So inductive loads like CFL or LED will have slight glow.
3) ALWAYS plug outdoor timers into GFCI-protected outlet.
Unplug timer from wall when working with lights, and cords.
Stand on dry surface or plywood and never bare ground.
Plug timer directly into outlet, and do not use extension cord.
4) Don't use LED Christmas lights because they have no warmth and look cheap and un-inviting.
Dec 18, 2012 | Hardware & Accessories
Outdoor 3-Outlet Photocell Timer
Photocell is 'seeing' lights and thinks it's dawn so it turns off.
When lights are off, timer thinks it's night and clicks back on.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
1) Turn photoeye away from lights.
2) Buy new timer since photoeye is first thing to malfunction on cheap Christmas timers.
3) Buy new timer at Lowes, and return defect in new package
Dec 02, 2012 | Hardware & Accessories
Flashing Christmas lights
Copy following link for general troubleshoot
How do I set different programs on the digit timer for my Christmas lights to come on different times??
Copy following link to help identify timer:
Note there are links to other brands.
Add comment and describe timer for more possible help.
Nov 27, 2012 | Hardware & Accessories
I have a EI600WC timer installed (by electrician) in my garage to control outdoor christmas lights (outlets in eaves). The switch will not turn the lights on!
Yes 100' maximum is problem. To work around problem, you can use timer to turn on a contactor, and then the contactor is not limited to 100' distance.
Copy following link to see wiring diagram, and you can wire it yourself:
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump2-300.jpg
http://waterheatertimer.org/H230A.html
Assuming timer was installed correctly ... did timer work when first installed, and then die?
This timer cannot be exposed to freezing temperatures because the battery will die in cold temperatures.
Ei600 timer is 5-year warranty version of ST01C timer, and both have same wiring and same battery.
Copy following link to see programming, wiring, and battery replacement
http://waterheatertimer.org/ST01C-program.html
If cold battery is problem, suggest using GE 15312 timer from Home Depot that has same 100' maximum and same load rating characteristics and same programming capability as Ei600 and ST01C, but GE timer is powered by the circuit and not a battery.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
You can install timer yourself.
Nov 29, 2011 | Intermatic EJ500C - Indoor Digital Wall...
Model N1502
Just plug it in and use the button to select 1-thru-8 hour run time.
N1505 and similar timers appear on following links.
http://waterheatertimer.org/Woods-timers-and-manuals-old.html#N1502
http://waterheatertimer.org/pdf/Woods-N1502-manual-english.pdf
Sep 16, 2017 | Woods INDUSTRIES 13660 OUTDOOR DIGITAL...
How do I set timer
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
1st Question: Can Woods timer model 16ULD/3A be used for Christmas light timing? The timer is in the garage not exposed to water at all.
I am unable to identify the 16uld timer.
Amazon has a page of their timers. I am familiar with all of these.
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Woods timers and manuals show on following link
If you can visually identify the 16ULD timer, then add a comment and I can answer your question.
That being said, any timer can operate Christmas lights.
If your timer has photoelectric eye, then it has to be placed outside where it can respond to dusk and dawn changes in light.
But there are some Woods timers that have photoelectric eye, and that feature can be overridden.
Again it depends on the timer, and clear identification would help numerous folk who are asking fixya about your same timer.
Dec 13, 2010 | Hardware & Accessories
Will the HB51R have to be placed outside to work on dusk to dawn.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Woods  INDUSTRIES 83660 OUTDOOR SECURITY LIGHT TIMER Logo
77 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
