Question about Epson TM-U220PD Matrix Printer
User Intervention required on Epson TM-U220PD
  • mahezabin Dec 10, 2008
    i have installed Epson TM-U220PD Matrix Printer driver Windows XP, everything was ready.......but the computer status shows "User Intervention Required"
    I tried to uninstall and restart the computer then intsall again and again restart.......but nothing improved.....
    Please help........
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Posted on Jan 30, 2009
I am pulling hair trying to install epson tm u220pd on xp and vista for weeks now please help
found some drivers but printer is not responding
Posted on Dec 02, 2008
2 Suggested Answers
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I unistall drivers and install it again it works but whenever I restart the...
This is a firmware bug that was resolved after ver 4.13, you may need to contact epson support to request a copy or upgrade as it is not downloadable through standard sources
May 11, 2011 | Epson TM-U220PD Matrix Printer
I need a printer driver for Epson TM-U220PD receipt printer for XP
http://www.posmicro.com/RECPRINTERS/EPSON/EPSON%20DRIVERS.htm here you go if it works let me know via a message or thumbs up if not i will continue to help you
Mar 16, 2011 | Epson TM-U220PD Matrix Printer
Trying to install epson tm u220pd with USB port, what drivers do I need? Plug and play does not install it in setup wizard
if your using TM-U220PD which is a parallel , you should connect it in parallel port then use this printer driver http://pos.epson.com/developers/techresdetails.htm?productpk=545
Feb 18, 2011 | Epson TM-U220 Matrix Printer
Where I can find driver of printer Epson TM U220PD for Windows7 ? ? ?
If there are any you'll get them here
https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?url_jsp=http://www.epson-pos.com/
Aug 19, 2010 | Epson TM-U220PD Matrix Printer
User Intervention Required Message Epson TMU375 receipt printer
Got to start/settings/printers and faxes .saelect epson 220 printer go to properties and select ports.Change ESDLPT1 port to lpt1 port and uncheck enable bi directional option .Apply and o.k.printer will work fine
Dec 30, 2008 | Epson TM-U220 Matrix Printer
good luck.
Dec 11, 2008 | Epson TM-U220PD Matrix Printer
Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Jul 29, 2007 | Epson TM-U220PD Matrix Printer
Epson TM-U220PD Matrix Printer Logo
2,938 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
