HITACHI SPLIT AC, MODEL NO ACE FOLLOW ME, RATING - 5 STAR, CAPACITY - 0.9 TON. PROBLEM - POWER LED CONTINUOUSLY BLINKING AND THE AC IS NOT RESPONDING TO ANY REMOTE CONTROL OPERATIONS.
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Press the Lock button on remote and it will work. Its toggle button and pressing it actually unlocks it.
Red led 9time blanking
white led 9 time blinking
Hitachi split ac. I turn on the mains, the fan turna on for a second then the filter clean red light starts blibking and ac goes dead. Only the power light is on and red light is blinking. Help please.
I m also having this problem
Same problem i have done the process as you tell above
Same problem led continuesly blinking
You need to count the blinks. 5 pause 8, 2 pause 6, 1 pause 2 etc...
SOURCE: SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
press the temparature up and down key simulteneiusly for 5 seconds on the unit when it is on.It is CHOKE indicator stating that it is time to clear your a/c filter.It happens after ever335 hrs of use
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
i have same problem.
I have same problem. Pl.help me.
Same here blinking white light with sound nd sound stops after 5 6 min..
Hitachi white light bling 4 baar kiya foult ho sakta hai bataye
Hitachi ac while light 9 times blinking
Three to four days l have faced same problem
What happened 12 times blinking Hitachi inverter split AC
