Question about E-Machines T2642 PC Desktop
Emachines T2642 Motherboard
Is there a common problem with these motherboards? Capacitor, IC,etc?
  • 2 more comments
  • jflachs34 Dec 03, 2008
    I replaced the power supply and its still doing the same thing. When I plug power in, the fron power button lights green around it but thats all that it will do.
  • Mouin Aboulhosn May 11, 2010
    yeah im sorry but if the light comes on and does not boot
    then its a faulty component and is expensive to fix
    if its not a new system buy a new one
  • Scott Jelt
    Scott Jelt May 11, 2010
    I don't know what to tell you that is the comon problem I have seen with Emachine PC's. Sorry.
  • Scott Jelt
    I have seen power supply problems on a lot of EMachines PC's. I don't know what type of problem you are having but could it be linked to the power supply.
  • 30 Answers
It's either a dead power supply or a fried motherboard. Emachines are cheap junk, their power supplies and motherboards die all the time, just look around here on Fixya for proof. Instead of saving a buck, consider buying a better brand.
Posted on Mar 27, 2009
I have an emachine T2642 desktop and I need to replace the battery. Where is the location to replace the battery
A desktop machine does not have a battery, only a power supply. Unless you are talking about the motherboard battery which is located on the motherboard inside the desktop, but if that is the case I highly suggest having someone at a local shop swap out your battery. Making a mistake could ruin the motherboard.
Apr 10, 2011 | E-Machines T2642 PC Desktop
Hello, I have a T2642 and my motherboard is not working. I removed the hard drive and installed it into another computer with windows xp that has a 40 gig hard drive with it. we put the T2642 Harddrive...
Password protected or not, data is data and will take up space regardless.
It is a strange one. Did you say that the drive worked and can boot from in another system? If it did then this pc is having problems. Even if you view the drive with a different OS the data will still be there.
Very odd.
Jan 04, 2011 | E-Machines eMachines Desktop PC
What are the hardware requirements for this motherboard in the way of memory, and graphics card? I have a pc2700 256M chip that is only seeing 191M of the total ram. Does it require ddr pc2100 instead? And...
Jeff, some of the system's ram memory is being borrowed. If you are using Integrated Graphics, this is where it is going.
[Integrated Graphics is also known as OnBoard Graphics.
On the motherBoard.
The GPU is soldered to the motherboard. (Hence you plug the monitor cable into the motherboard, via a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector )
A dedicated graphics (adapter) card has it's own GPU.
(Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU ]
Integrated Graphics uses some of the system's resources. The Processor, and Ram Memory.
A dedicated graphics card has it's own Processor, and Ram Memory.
(GPU, and graphics ram memory)
PC2100 is DDR Sdram that operates at a frequency rate of 266MHz.
PC2700 is DDR Sdram that operates at a frequency rate of 333MHz.
http://en.wikipedia.org/wiki/DDR_SDRAM
[Frequency Rate:
Proper 'computer speak' for Speed.
'Speed' is slang.
DDR Sdram:
Double Data Rate Sdram
Synchronous Dynamic Random Access Memory
MHz.
MegaHertz
Mega = Approximately 1 Million
Hertz stands for Cycles per Second.
PC2100 can operate Up To a frequency rate of 266 Million Cycles per Second.
PC2700 - 333 Million Cycles per Second ]
No, using PC2100 is going backwards, and will not help increase the Amount of ram memory, seen by the computer.
According to eMachines Support, the T2642 desktop computer's motherboard, uses an Intel 845GV motherboard chipset.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2642
[Chipset, and Chip are slang terms for I.C.
Integrated Circuit.
The motherboard chipset used for the technology of the T2642 motherboard, is the Northbridge, and Southbridge chipset.
(Motherboard's for the Intel Core i3, i5, and i7, do not use this motherboard chipset technology)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
Memory Slots = Ram Memory slots ]
The Northbridge chip handles the faster processes of the computer.
The Processor, Ram Memory, and high speed graphics.
High speed graphics being AGP, or PCI Express.
Not a graphics card inserted into a PCI slot.
Integrated Graphics, or a graphics card inserted into a PCI slot, is a slower process of the computer.
Slower processes of the computer are handled by the Southbridge chip.
Northbridge (computing)
vhttp://en.wikipedia.org/wiki/Northbridge_%28computing%29
(At the end of the Northbridge article's first sentence, you will see - southbridge, in blue.
Left-click on it for more info on the Southbridge)
Continued in a Comment
Aug 06, 2010 | E-Machines T2642 PC Desktop
T2642 Emachine upgrade,can you recamend parts that are compatable 1GM memory. Hard drive 160 MG Viteo memory over 128 GB Thanks
Use this site to help you upgrade you T2642 e-Machine. The link shows what can be upgraded. Includes max memory the system can run;
http://www.cputopia.com/emachines-motherboard-case-cpu-replacement-t2642.html
Hope you find this helpfull.
Mike
Oct 21, 2009 | E-Machines T2642 PC Desktop
EMachine T2642 motherboard
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
jashim12
Apr 10, 2009 | Computers & Internet
EMachine T2642 motherboard wiring diagram
need wiring for a fc motherboard old p3 board
Apr 10, 2009 | Intel Computers & Internet
No power when i turn on the computer and everything is plugged in
Most likely it is a motherboard issue. I have seen a lot of these mobo issues in my shop recently. You can inspect the mobo yourself.
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). A failed video card will also give you "No signal message", but the computer should sound normal when starting up. Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They (mobos) can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
Mar 16, 2009 | E-Machines eMachines Desktop PC
Old emachine T2642 will not boot...disk monitor LED stays on and CPU fan does not rotate...no boot access to CD-ROM, or disk drives...changed power supply...think it might be BIOS backup battery...
It sounds like a dead motherboard. Try removing the CMOS(BIOS) battery and replacing it. Then try removing and replacing the CPU as well. If you get the same result then you might be looking at replacing the motherboard.
Regards
Dec 20, 2008 | E-Machines T2642 PC Desktop
Emachine t2642 power supply
Apparently this model has a bad motherboard, which manifests as a power warning and eventually a refusal to boot up. You can replace the power supply (as far as I know, any generic one 250-watt or better will work) but it's unlikely to help. You can buy a new motherboard (and new power supply, if you want to) direct from eMachines, but it's also likely to fail pretty soon. Your best bet is to get a new computer (NOT an eMachines one) and put your hard drive in as a slave so you can get your data off.
Jun 19, 2008 | Computers & Internet
E-Machines T2642 PC Desktop Logo
200 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
